Help CEL
Old Jun 12, 2015 | 07:05 PM
jdmdohcpower's Avatar
jdmdohcpower
Default Help CEL
Be had my halltech no tune, the plastic one on for about 30 miles now I'm getting fuel trim lean light. Does this mean I have to remove the intake?
Old Jun 12, 2015 | 07:45 PM
TARANTULA's Avatar
TARANTULA
Check for leaks between the joints. Disconnect the battery to clear the CEL drive the car a few miles. IF you still get the CEL after a few miles take the intake off.
Old Jun 13, 2015 | 07:31 AM
jdmdohcpower
I think the pcv line is the issue. Going to run a new line without the quick disconnects. If I disconnect the battery will I lose all me settings like gauge settings, seat and exit features. I don't want to deal with all that again so I may just do a pop in at the dealer and ask them to clear it
Old Jun 13, 2015 | 11:46 AM
jaden61's Avatar
jaden61
2017 C7 of the Year Finalist
Clear that and the warranty?
Old Jun 13, 2015 | 11:58 AM
ParishM's Avatar
ParishM
adding a CAI won't void the warranty !
Old Jun 13, 2015 | 12:11 PM
Arctic Blastoff's Avatar
Arctic Blastoff
When it happend to me the gromet blew off,make sure its tight on the tb,then check the filter mine just pulled off so i had to tighten it.
Old Jun 13, 2015 | 12:26 PM
Halltech's Avatar
Halltech
Supporting Vendor
St. Jude Donor '09
The OP contacted me the day he had the issue. I walked him through the troubleshooting, and found out that he had broken the locking tab on the PCV quick disconnect to the nipple receiver. The PCV line would not stay connected, and the un-reported air will cause a lean code within seconds on the second startup.
Simple to fix. I recommended for a temporary fix, to use an equal length of 5/16 fuel line hose and plug one end into the nipple, and the other into the clean side of the dry sump reservoir. That whole line is probably $20 and I offered to pay for it.
Any Auto Parts store like AutoZone will clear codes for free.
__________________
"World Class Performance for your Corvette"
Intake Design and Engineering since 1999
Halltech Systems, LLC
423-915-6056
For service email:
orders@halltechsystems.com
www.halltechsystems.com
To Help CEL
