Nitrous oxide
Old Jun 25, 2015 | 07:00 AM
Thomasmoto's Avatar
Thomasmoto
Default Nitrous oxide
Has anyone installed nitrous oxide on a 15 Z06 yet? If so, where did you source the fuel from? Separate tank? Or the stock fuel line? What is the psi at the line on the driver's side that is so easy to get to?
Old Jun 25, 2015 | 09:18 AM
JHEBERT's Avatar
JHEBERT
So u wanna spray your z huh? Well, the line going TO the HPFP is prob around 60psi (I would check it) and u should be able to use that as a fuel source IF your car is otherwise stock. If it's modded, u may be cutting it close on overall fuel delivery and I would use a stand alone fuel system. Some are small, and can be put in various places. The one for my c6z uses a 255LPH pump and holds about 1/2 gallon of fuel. Easy to tune (fuel press regulator adjustment) and I use race fuel in it. Easily supports 2- 150 shots
Mod to about 700-750 rwhp and then hit it with a 75 shot on the Dyno and report back just how much more power the "small" shot netted to the tire, be ready for a pleasant surprise
Old Jun 25, 2015 | 09:39 AM
Nitrous Express & Snow Performance's Avatar
Supporting Vendor
We have couple kits on ZO6's and you can get the fuel off the fuel line.
Here is our plate kit-
http://nitrousexpress.com/203024/0/0...te-system.html
PM me if you have any more questions and for the special forum price.
Billy
To Nitrous oxide
