Changing pads on carbon ceramics
Welp, after four track events it looks as if we need to change the front pads.
My question is, I don't see anything on the GM instructions on cleaning the rotors or getting the pad material off the rotors before installing new pads. Do you not need to do this for carbon ceramics rotors? Or if you do, then how do you remove the pad material? I don't know if sanding them is s good idea on these rotors...
Received 3,810 Likes
"Ask Tadge" Producer
As for "plugged vents", I wouldn't worry about them until it's time to weigh your rotor. You'll need to do this to determine when to replace it. When weighing it, you want it as clean and dry as possible. So with that, remove the rotor and scrub it gently with nothing more than soap and water. Car wash soap is fine. Hose it down and let it dry.
I've done five track days this year, and the front pads are done. The rear pads are down to 8/32". From what I've read on this forum, that sounds about right...
Thanks!
Mike
