Safety issue at Spring Mountain
I think SM does a great job but they can't change the weather and it's not their fault the cars overheat. Where would they move to? Somewhere with rain and snow? At the level they're running the stage 1 the cars shouldn't be heating. That's a problem GM should address.
no worry, you have to sign a waver at SM, as well as post a CC in case you damage the car. if the PS fails and you hit something, 10k can be charged to your CC.
this all has to be agreed upon before you are signed up. i realize that the bond or limits are not specifically intended for mechanical failures like the pump issue, but the contract does not specify any cause exclusions.
I did a version of SBC and a Stick's modification to get more airflow to the area over the PS motor, and had no issues in mid to high 80dF temperatures running for the whole 20/25 minute session. Obviously not the same as running in 100dF ambient, but not far off.
Bish
Bish
When I was driving at Spring Mountain and my ps went out I honestly didn't notice it until Howie said his went out. The steering was stiffer but it didn't stop steering. Is it dangerous? That depends on whether or not you are able to steer it without the power. The other issues don't seem a danger, just an aggravation. I never felt like the power steering going out was dangerous because I could still control the car it just took more effort. I think that people who haven't experienced the loss of the steering should ask questions rather than give their opinions on the severity of the problems. As Jimmy Buffet would say " don't talk about the ocean if you've never seen it".
True. But, I don't have to go out in the rain to know I'll get wet.
#33
I think that GM is wide open for a lawsuit. "They subsidize our SV class in unsafe cars" I can hear an attorney saying! All an attorney has to do is show the data for failures, and that GM knew about it which is pretty easy to prove. It just takes one guy to have a problem on street or track that causes injury and here comes a law suit. I sure hope no one gets hurt. Yes to the above, i have lost PS on two different cars coming over Vail pass over the years, and its no fun and dangerous ( idler and serpentine belt failures that were my fault because of mods). Yes you can steer the car depending on where you are and your speed but I can see situations where its not so easy going slower on tight mountain roads. maybe its only me. They should recall these cars ( a disaster for marketing for a marquee car) or provide a fix and get ahead of the curve for at least the PS issue because it could be life threatening. It would seem logical their engineers have or can come up with a fix. I am sure their legal department is already involved.For the engine/trans overheating on the track they can probably avoid liability unless someone sues for misrepresentation of the facts. The Cobra R guys sued ford successfully I think (add something if I am wrong) in the 90's for misrepresentation of the true HP of the car. It was way below stated values. Ford lost that one. I am sure I will get Lit for saying this by those who are indignant toward anyone who makes negative comments about their brand especially being a noob and coming from a ford. But my familiy has had C-3's for 3 generations and still does, so its not a knock on corvette. I have a 2015 Z07 A8 and had 3 C -3's one of which I still have so I want them to fix it so I can enjoy this sick machine! Not just taking potshots from the sidelines. There is bound to be a fix available and the car should do what it was represented to do. GM should step up and retro fix it for 2015/2016 and then fix it for good mid 2016 and increase the price of the car to cover their additional costs. I am headed to track in next couple of weeks after a business trip. I doubt I will be able to push the car hard, but I have no choice during the summer but to drive in 100 degree ambient temps or race only in the spring and fall. We all have other things to do than screw around with this kind of stuff on a $100K Car. If I am wrong on this, i am sure someone will tell me and hopefully i can forget about it and enjoy the car...........bob noob
#34
#35
"most capable street car ever with track potential if you want to design your own modifications and pay for them, and no track-use warranties"
not sure this plays well with the marketing dept...
sad...the car shouldn't have these problems for HPDE use.
#38
Hoping SM will respond
I attended the 2 day with my grandson and we both had a blast, and all the staff was professional! To hear this story surprises me! I hope someone from SM's executive staff investigates and responds to this post and notifies GM of the issue! GM has had enough issues with safety lately, and I would hope this gets to the executives of GM before someone is seriously injured or killed!
#39
#40
Didn't Tadge say at one point the car was engineered to run without overheating up to 86 deg F. With that said, 110 degweather is doin' what was expected for the Z.
Would have been nice if that were published in the ads.
