MGW Shifter
Old Jul 3, 2015 | 04:12 PM
3 Z06ZR1's Avatar
3 Z06ZR1
Default MGW Shifter
A member C7x2 came over and I checked his Sweet ride out.
He is waiting to pick up his Z soon.
He let me sample his MGW. My order is in. This should help quicken the M7. Not only quicker but smoother.
Holy cow they are built like a tank and a very short throw.
Love the Z06. Even bumper to bumper in traffic in 95 degree heat is no issue.
Old Jul 3, 2015 | 04:48 PM
badhabit_wb's Avatar
badhabit_wb
Just installed one. They're great. Be sure to cut the boot like they say in the video and start on the drivers side putting it in.
Old Jul 3, 2015 | 05:06 PM
3 Z06ZR1's Avatar
3 Z06ZR1
C7x2 said he would help me but thanks for the tip I need to watch the video.
Old Jul 3, 2015 | 05:51 PM
badhabit_wb
I've had the boot off 3 times. Installing the first time sucked. The second time was pretty easy. The third time took less than a minute to get it fitted around the mgw boot.
Old Jul 4, 2015 | 12:43 AM
JackTripper's Avatar
JackTripper
Turn 12!
Had one in my C6Z and now have one in my C7Z. Awesome. Night and day over stock.
Old Jul 4, 2015 | 09:07 AM
408sbc's Avatar
408sbc
My MGW is sitting in a box in my living room. Now just need my car to show up. Tick, tick.....
Old Jul 4, 2015 | 11:22 AM
Frankie2blue's Avatar
Frankie2blue
Spray that rubber boot with armour all before installing and it helps immensely. George from MGW actually told me that and it really helps a lot.
Old Jul 4, 2015 | 11:37 AM
badhabit_wb
I found out on the second or third time I put it on that if you stretch it really far on the drivers side and get it all the way down and then continue to stretch it as you go around that it will go on easy. I also used a plastic trim tool to help stretch it down on the passenger side.
Old Jul 4, 2015 | 05:42 PM
rotax's Avatar
rotax
Can you post a picture of the finished install?
Old Jul 4, 2015 | 07:40 PM
badhabit_wb
Do you want a photo of the finished install? You honestly can't tell any difference in now and before it was installed. When it's all put back together it looks stock.
Old Jul 4, 2015 | 08:49 PM
JackTripper
Turn 12!
I used silicon spray.
Old Jul 4, 2015 | 08:53 PM
badhabit_wb
If you stretch the boot as much as possible it slips down on the drivers side easily. Once I found that out I stretched it all the way around. When I got to the passenger side I pushed it down with a plastic trim tool. I was afraid lubricant would cause it to slip off later.
Old Jul 4, 2015 | 09:48 PM
408sbc's Avatar
408sbc
.....unless you go with the flat stick and round ball option - like me. Check out MGW's website.
Old Jul 4, 2015 | 10:51 PM
rotax's Avatar
rotax
Great, thanks.
To MGW Shifter
