Engine Build plaque?
Old Jul 13, 2015 | 09:41 AM
jcthorne's Avatar
jcthorne
Default Engine Build plaque?
Take a look at the pic below of my LT4 engine. Toward the front, on top of the intercooler tubes there is an engine builder plaque.
I was at a car show Sat night and there was another Z06 there. His did not have a plaque there, nor even the flat boss to mount it on that is a part of the intercooler tubes. IE his tubes were a different part.
Why the difference?
Old Jul 13, 2015 | 09:48 AM
mjpcowboy's Avatar
mjpcowboy
Z07 package has the engine build plaque as it is built in Bowling Green
arcticblast's Avatar
arcticblast
Cruise-In VI Veteran
Cruise-In VII Veteran
Z07 have the hand built engines with plaque.
Non Z07's don't have this.
Old Jul 13, 2015 | 09:49 AM
mdz06vetter's Avatar
mdz06vetter
St. Jude Donor '05-'10-'11-'12-'13-'14-'15
Is yours Z07? And, he was NOT? That is the difference.
Old Jul 13, 2015 | 09:51 AM
jcthorne's Avatar
jcthorne
Thanks guys. That explains it. Nubie coming up to speed.
Yes, mine is a Z07.
Old Jul 13, 2015 | 10:12 AM
SLWRNU's Avatar
SLWRNU
2026 Restomod of the Year Finalist
Or if you choose the Build Your Own Engine option you will get the plaque.
Old Jul 13, 2015 | 11:27 AM
Steve Snake Driver's Avatar
Steve Snake Driver
Melting Slicks<br><img src="/forums/images/ranks/3k-4k.gif" border="0">
Running production change? I'll have to look, but I thought my plaque is on the side of the intercooler housing, not the top front as it appears in the picture.
Old Jul 13, 2015 | 02:56 PM
foreverfuelie's Avatar
foreverfuelie
Yes Steve Snake Driver is spot on. Your Z07 is a late build. Earlier Z07's that were assembled in Bowling Green at the PBC had their plaques on the right (passenger side) front of the blower base below the removable top. You nearly need to hold the PCV tubes and harnes out of the way a little to see it.
Old Jul 13, 2015 | 05:33 PM
elegant's Avatar
elegant
Or retrofit the front intercooler tubes with the new ones, and remount your plaque. BTW, the parts for this retro are $622.00.
John
To Engine Build plaque?
