Halltech's Stinger-RZ GEN 2 RECORD TORQUE DYNO PULL
#61
Supporting Vendor
St. Jude Donor '09
I agree that it would be nice to see some quarter mile before and after runs. As soon as one of our customers decides to make those numbers available, we will post them. Most of our customers are not into racing from what I have seen. Vengeance Racing has results with our intake, but not a side by side before and after since our intake is just a part of the whole package they offer.
There are no drag strips anywhere in Wisconsin or within 200 miles that I know of, besides the fact that no one on the forum would believe our results.
For those folks that just ordered this last week, thank you.
We have stock, but not enough help. I am hiring two more guys this week, and changing shop locations to a bigger shop.
__________________
"World Class Performance for your Corvette"
Intake Design and Engineering since 1999
Halltech Systems, LLC
262-510-7600
For service email:
orders@halltechsystems.com
www.halltechsystems.com
262-510-7600
For service email:
#62
May be a silly question: just got my Z and am impressed with the numbers. How easy is this to install? Last CAI I installed was on my C5 and had to take the whole front end off... Any need for a lift with this? Thanks!
#64
Ive installed the Gen 1 and Gen 2. Its not all that hard but it takes a bit of time the first time only because your not sure what you are doing and you want to do it correctly. Id say the hardest part for me was adding the extension hose. Its not hard but just taking your time not to break a plastic fitting. No you do not need a lift. I have a lift and you don't use it for any reason. Like others said just follow the directions and watch the video. This is a #1 mod.
#67
Supporting Vendor
St. Jude Donor '09
The intake can actually be installed in 5 minutes since we assemble it completely for you. The engine bay preparation is about an hour of work, and somewhat tedious. What happens occationally, is the shop that goes to install our intake thinks that they can bypass the prep, and guess what?
Not enough room to install our oversize airbox (plenum) I had a carbon fiber intake returned for that very reason. I talked with the installer for 30 minutes and could not figure out why he could not make it fit. This was our last CKNZ and of course problems.
Refunded the customer, and got the intake back pristine as if it had never been installed. Plus the hose that must be changed from the radiator to the t-fitting was never installed, and the lower zip tie not used to push the large hose over. The intake will not fit at all without these simple changes. I installed it on our Z06 since we had previously sold our system. Took 5 minutes.
#68
Paul
#72
Dyno numbers are indeed impressive. I would like to see (on average) what the stock AFR plot looks like bone stock and then what it looks like with only the Halltech airbox installed with stock tune. Guessing we will see a leaner AFR with the Halltech intake but "within an acceptable/safe range"(?). I have heard others say that the stock tune AFR "runs fat" - but again, that is an opinion. Even though there may be no tune involved, might GM claim the a leaner-than-stock AFR condition may contribute to a failure and try to stand that ground on a warranty claim? I am very interested in the Halltech, but as many others, do not want to risk my factory warranty. Maybe this has been discussed, but I can't find it in other threads that I have searched.........
#73
Supporting Vendor
St. Jude Donor '09
#74
I'm asking an honest question here - not being a smart azz and not knocking your product. I simply want to understand if it's the product you are selling or the tune that is responsible for these gains.
I see your big filter requires a tune and nets around +50 RWHP. However, when I tune a *stock* C7Z I can get +50 RWHP (with the stock filter and airbox).
Perhaps the performance increase you're seeing is from the tune alone or am I missing something?
#75
#77
#80
Former Vendor
