Starting Over: C7 Z06 Overheating Issues
#101
Taking lawdogg149's lead..
When I had the car on the lift doing a general inspection, it seemed to me that the (unshielded) oil lines were too close to the cat, oil cooler too. Jeremy , lawdogg149, had already addressed this issue and was kind enough to send me pics of what he did and the materials he used to do it. Ordered the materials last week and installed yesterday.
Taking my M7 Z06/7 to COTA on the 5th. No doubt it will be hot in Austin, mid to high 90's with high humidity. First time on a big track with it, hope cooling stays within limits. We'll see.
Thanks, lawdogg149, hope I have the same results at COTA as you have at Road Atlanta.
Thought I would share a couple of pics for those who may be interested.
EDIT: Added pics of CAI air tube wrap at bottom of post
Oil lines as it came from factory.
What I did yesterday using Heatshield Products part#110614 (1) and high temp heat tape.
Edit: Added CAI air intake tube wrap....
What I did yesterday using Heatshield Products part#110614 (2) and ties, part#350010 (3)<br/>(windward side of lines)
#102
Hey just wanted to say thanks guys for putting this thread together. I'm looking at picking up a Z06 possibly this next spring and had heard some overheating issues with the Z06 and this thread calmed my nerves a bit (I don't track my cars at all so it sounds like it's not a worry for me).
Thanks again.
Thanks again.
tonypittman (11-17-2015)
#103
Descartes,
Thanks very much for posting the detailed layout!
Bob,
I thought earlier that this (the low pressure return to the tank) is the most practical point to add an additional cooler. Whether a cooler is in the high pressure or low pressure portion of the lubrication circuit avoiding excessive pressure drop across the cooler is critical. Remember on the high pressure side any pressure drop across the cooler means pressure (and associated flow rate) are reduced for items downstream of the cooler which are actually the focus of the lubrication.
The air ducting shown on one of the other cooling threads would be much better utilized in applying a cooling blast to a high flow cooler on this return line rather than aiming it at the outside of the block mounted fluid to fluid exchanger. If you want to add an air blast to an existing component then thermally bonding fins to the dry sump tank and increasing airflow to this part would be more effective than air flow over the fluid to fluid exchanger but still a marginal increase compared to a good oil to air cooler.
Bob,
Jim
#104
[QUOTE=Gomer;1590358129]Taking lawdogg149's lead..
Gomer, have you seen any appreciable decrease in temps on the track with this modification?
#105
[QUOTE=Emmdmd;1590934491]
Gomer, 1, any data?
2. I noticed you completely wrapped the oil cooler. Doesn't it need some air flow?
3. Did you use the same heat shield product for everything?
#106
If you watch this video at the 9:55 mark, from Ron Fellows, they talk about the over heating issue on the Z06; although, very briefly. The guy, I can't tell if he's Ron Fellows or Chevy, but he states there is an aux water cooler available from GM that will drop the water temp by 25d. Sounds like it fits both the Z06 and Stingray, did not distinguish between A8 or M7.
