In my ZR1, I got a check engine light and had OnStar read the code. It was a intercooler system fail. I don't remember the exact message that OnStar read, but it was clear enough that it was the intercooler system. In my case, it wasn't the pump, it was the relay for the pump. I'm going to guess that something similar would occur in the C7ZO6. Having a shop manual with all the codes available would certainly help to determine if there is an intercooler failure code on the C7.
If the pump stops working will you get some type of warning from the DIC?
The coolant pressure sent to the intercooler comes from the engine water pump. there is no stand alone pump for the intercooler. So, yes, you would get a warning that the engine is overheating.
Umm...no, the intercooler has its own elec pump and its on a relay. At least on the zr1 this was the case....
You're probably about to have egg on your face since Barry is one of the engine builders in Bowling Green.
He may build engines but he doesn't know anything about the intercooler system because he's dead wrong. The Z06 has a stand alone intercooler cooling system with its own electric pump just like GM has already been doing for the past several years in the ZR1, ZL1 and CTS-V. The water pump on the engine has nothing to do with the intercooler system. So how can an LT4 engine builder not know this especially when he sees the coolant lines directly on front of the SC when he builds it?
Correct it has its own pump. I was just looking mine over today. Also has its own coolant reserve which has a large air bubble in a so called pressure sealed system.
Barry led me astray? Say it ain't so! I guess I could have popped my hood to verify.
After further research, I stand corrected. I was led to believe that the intercooler was fed by the engines cooling system. We do not see the engine after it leaves the PBC & I have not had the opportunity to look under the hood at an installed LT4. I guess I need to study up a little more on the complete package and not just the engine.
Sorry guys.
After further research, I stand corrected. I was led to believe that the intercooler was fed by the engines cooling system. We do not see the engine after it leaves the PBC & I have not had the opportunity to look under the hood at an installed LT4. I guess I need to study up a little more on the complete package and not just the engine. Sorry guys.
Thanks barry for all the info you do provide. You are GM's finest and you make me proud of the brand.
Sorry guys.
Don't sweat it at all, the info u provide us here in this forum is priceless
Thanks y'all for the vote of confidence. I do try to relay to the forum all the information that I can to help you understand your Z & your LT4 & to make your ownership of a World Class Supercar a little more special. Keep the questions coming & know you won't get the Corporate runaround from me, unless GM says no.
Barry
Sorry guys.
You need to get outta the engine shop once in awhile.
You want the IAT's as close to ambient air temps as possible. If you were running engine coolant through the intercooler/heat exchanger system, the best you could do IAT wise would be what your thermostat would allow. I'm guessing the LT4's stat to be around 200 degrees. 200 degree intake air temps aren't good if you want to make decent power.
Barry
It's good to have you around here, Barry.
Please know that many of us very much appreciate your contributions to this community.
Back to the original question - probably not. But the engine would begin to pull power pretty quickly as the IATs skyrocket. The blower on this car was chosen for packaging considerations. It is not an efficient compressor, adiabatically speaking, and I would not be surprised if the compressed air charge exits the rotors at 300F or more under full boost. So you will know pretty quickly if that intercooler stops working.
Why are you asking anyway?
I can't wait to get my car and start digging into this stuff.
