I've noticed that my driver side mirror keeps loosing its position without me changing it. It used to be once in a while but recently every time I start my Z it's turned all the way in. Tilting up and down with reverse works fine. Has anyone else had a similar problem? Not sure if there's anything I can do to troubleshoot it myself or if I should just bring it to the dealer. Thanks!
My '15 started having problems recently and it's very annoying! Intermittently, my driver's side mirror will drive down (and sometimes up) when I have Easy Exit turned ON. I do NOT use Reverse Tilt - never have. I have tried the Factory Reset, FOB swap, Memory #1 & #2 reset and my dealer reprogrammed my Memory Seat Module. I know it's not a power issue since my battery is brand new. Sometimes it will lose its mind when simply cycling back and forth between Memory # and Exit. My factory warranty recently expired so my approach to this problem has changed a bit. I plan to replace the driver's Mirror Tilt Module next since it only happen on one side. Also, the seat and steering wheel tilt never fail.
I have the same mirror movement. I think its just not holding its position over bumps, door closing...not sure, but annoying.
