Radar detector
It is true that the wireless/battery powered units don't test as strongly as the wired units. However, in practice it has saved me (er...uh.......I mean, "properly alerted me as to a radar/lidar signal") MANY times, and does everything you need. You learn your local falsing areas.....you ignore X band signals, and when it goes off and you think it's real....SLOW DOWN and you won't get a ticket. For instant on situations.....like any other.....hopefully they will tag somebody in front of you and it will go off.....then...SLOW DOWN.
As with any detector....it is not a license to speed. A whole heap of common sense is required.
I really don't think that having a wired detector would have made any difference in my results (flame suit on; radar detector threads are like oil or wax threads; everyone has their favorites and some can be passionate about them).
I am currently running a V1 in my Z06. I wish they would add some features like GPS, but I love the directional information that V1 gives you that nobody else does.
- use a small screw driver or pry tool to remove the cover off the wire harness compartment behind the mirror - remove the harness plug from the compartment and unplug it (separate the connector) as it is easier to seat the mirror tap wires - if you are doing this yourself, no extra hands, you will need to set up good lighting so you can see the area where the mirror tap ends are supposed to go
- remember that the mirror tap goes into the harness on the car side (meaning the part of the wire harness that goes up into the roof, not the side that goes to the mirror) & keep in mind that it will power the detector only after the car is started, not just in accessory mode
- it might be a tad harder to close up the cover if you do not have the harness tightly seated back exactly where it was, and the fact that you have the mirror tap wires coming from it....some have put a small notch in the cover to allow the mirror tap wires an easy way out (something i did not do, nor did i feel needed, but my cover was a bit hard to reseat, however it has never come off)
- MirrorTap sells a 9" & 12" long wire....the 9" was just right for me - also be sure to get the MirrorTap with the smallest ends (they have 2 sizes, you want the smaller ones as they will go in easier)
- here is the thread that will guide you:
https://www.corvetteforum.com/forums...or-15-z51.html
