FE6 to FE7 conversion
Which CAN module does the calcs for the eDiff? What about MR? Launch squat detection? All of these things (and many more) could vary between a Z06 and a Z07 car.
Now it's not like you're adding a feature that wasn't there, so the eDiff isn't going to "Crash". But the calibrations may be off in many different modules, and I don't think any of us, short of maybe people like HPTuners, have a firm grasp on even what modules are IN the car, let alone which ones need to change.
If I had a Helm manual I'd sit down with Vehicle Spy 3 and start at it, but I'm waiting for manuals before I start dorking with my car.
This isn't so much about converting an FE6 to an FE7 car any more. This is an ECU that gets tied into the CAN bus and a new set of dampers.
The ECU comes with software that allows the dampers to be programmed based upon the incoming parameters across the CAN bus, primarily the accelerometer and speed.
As soon as you change the tires, the refined e-diff settings go out the window. I might be in the minority here, but I'm not overly concerned about the diff here.
The DSC module precisely controls the damping on all four shocks independently.
In the Porsche world (where the OEM shocks have a greater range), they can swap in the DSC box and notice a big difference - then if people want even more, they upgrade the dampers.
In the Corvette world, while we might think the MR dampers are high end, I've always felt that they were pretty lacking. At some point, everything comes down to a budget and they are suitable for a very wide range of customers.
The DSC box dramatically increases the responsiveness and precision of the commanded damping levels, and the Tractive DDA dampers have a much wider range than the factory, allowing a much softer, or much firmer shock based upon the commanded level.
Another way to look at it, as you're going around a left hand corner, the DSC Sport package will stiffen the right side dampers as the car begins to load up, and simultaneously soften the left side (so that hitting the curbing doesn't upset the car). The amount it stiffens is based upon speed and G-Force.
When the car gets on the straight, the shocks ease up and allow it to float a bit more. When you start to get on the brakes, the front will get tighter and hold the car up.
I believe there is a small amount of dynamic range in the factory MR shocks, but it's not very noticeable and to me, the car needs suspension work.
One thing to add here is that they just added this same setup (different valving and such) to a Gen 5 Viper TA and it ran 3 seconds faster around NCM than a Gen 5 Viper ACR - same driver. I believe this was a 5-6 second swing.
For those interested, read up on Rennlist and Viper Exchange.
https://www.corvetteforum.com/forums...ndard-z06.html
I spoke to the Chief Suspension Engineer about this last Summer and he was pretty clear this was something GM had no interest in supporting because of the way the calibrations in the PTM and eDiff were tuned to the FE7 suspension.
I thought it was pretty ridiculous that GM wouldn't support this but at this point I think the DSC shocks and controller are likely a better route anyway.
On your second point, I couldn't agree more. I have a lot of faith that the DSC/Tractive equipment will significantly outperform the stock FE6 or FE7 suspension.
There is a good number of fast Z06 guys that either don't have Z07 package and/ or not interested in the full package but still prefer a stiffer suspension. DSC shock sounds promising but it sounds like it will be expensive in comparison to FE7 conversion. I am sure I will not be breaking any track records
but it does help to have slightly stiffer suspension.
Attachment 47942254
I'd also like to make something that would send the "Valet Mode Camera On" PID broadcast every time he car was put into D, but then I'd need to know the module and PID. I can likely sniff all that out with Vehicle Spy, but if you've got any info that might kickstart it, let me know!
I would guess Module 23 does the camera?
Very little info in the Vehicle Performance Data Recorder, other than trouble codes, calibration part numbers etc.
Short video showing the Folding Top Control Module.
As mentioned above I am not sure how many modules have different calibrations in them that are different from the FE6 to FE7 suspension.
I am thinking possibly the Chassis Control, Rear Differential Clutch Control, Electronic Brake Control, and the Suspension Control Modules have different calibrations. I could pull and document all of these calibrations out of my Z07 car. There is only one other Z06 in my town that I know of but it is also a Z07 car. If anybody here that has a Z06 with the FE6 could also have there calibrations documented that would be a starting point.
I also have been told that the PTM and eLSD programming are different with the Z07 but to be honest it seems like that programming only works well when you stay with the tires (and more importantly tire sizes) the car came with. I'll post up a separate thread on my experience with 315F/345R Hoosiers but I can sum it up by saying PTM wasn't something you could rely on (but luckily didn't get in the way either).
PTM is nice though when it's working as when I was following Gary around the slow carousel at Summit Main he could definitely pull away from me under power while I was trying to manage the oversteer. He has a Z07 car on fresh MPSC2 and I was in my FE6 car with some used Hoosiers.
Jvp - I don't buy the "hope everything gets installed" bit. It's freaking software and they already have the tools in the dealer to update software on the car. They sell the updated MR cals and trust a dealer to install that. Franlkly, it seems to me far more likely that a tech would screw up something mechanical when replacing a motor (or brake or suspension part) than the software.
I feel like GM is just being obstinate on this. I made my bed when I bought a non-Z07 car but I believe there are a lot of people that didn't want to pay an extra $8K for the CCBs on a hard core track model anyway. They do have a GM performance parts division for a reason.
Gary - I wish I'd known Mike was doing that when I saw you two at the PCA event. I'd be interested in this if it doesn't affect the ECU and powertrain warranty. I suspect that a Z07 with 315F/345R Hoosier setup is going to be very loose so some adjustability might be nice.
Have you or any one heard of any one making progress on having a re flash done on a z06 to upgrade it to the Z07 (FE7) and getting running the correct code to manage the Z07 shocks?
Thanks in advance!
I have been following that thread and posted several times but the guy has not yet confirmed. I also PM'ed him twice with no response.
I actually met with my Dealer/service guy yesterday and he claims when the car gets flashed it is VIN specific and he can NOT load in the FE7 settings.
I have been checking at the DSC site and the controller for the C7 is still not available for sale.
I am currently running FE7 springs which for me has been a huge improvement IMO. Much less body roll and lean during braking. I am running P-Zero racing slicks and an LG sway bar.
Going to Sebring in December with Chin and am a little worried about that rough track with the car now being much stiffer, but I will soon see. All I do know is we run at Barber Motorsports track often and that track is very twisty and the car handles much, much better.
I am thinking of calling a few other dealers that sell GM performance upgrades (including the FE7 rough track flash) and see if I get any different answer.
