Xpel Install
Old Oct 3, 2015 | 11:40 AM
FrcFed8's Avatar
FrcFed8
Default Xpel Install
Question for those who did whole panels. Is it normal to have a water bubble or 2 the size a little smaller then a pencil eraser in film 24 hours after install?
I did ask installer and he said its normal to have some small bubbles for 2 days to 2 weeks until film cures and dries. Said xpel is breathable to a point and will dry faster in sun. Almost did whole car minus root and back of rear bumber and only 3 small bubbles.
Just asking to see if this is the norm.
Old Oct 3, 2015 | 12:10 PM
thebishman's Avatar
thebishman
Perfectly normal. Park it in the sun as much as possible.
Bish
Old Oct 3, 2015 | 12:28 PM
BOBSZ857's Avatar
BOBSZ857
They will go away after a few good days in the sun. If not gone completely, go back to the installer and he can work on them for you.
Old Oct 3, 2015 | 12:48 PM
mikegaan's Avatar
mikegaan
Normal. My installer did immediate fixes. He used a small syringe to 'suck' the air out of the bubble, then squished down with his thumb to get the adhesive to re-stick. Fixed. Took him a minute. They have not reappeared. Areas around sharp corners are most susceptible, like around the edges of the brake cooling ducts, or the lower door sills.
Old Oct 3, 2015 | 08:04 PM
Mr. Sparkle's Avatar
0Mr. Sparkle
Former Vendor
Moisture bubbles are common and will dry up over time. Not a concern. park in the sun as mentioned above
Any air or air mixed with moisture is a concern. Air will not disappear on its own. Air is also more sensitive to temp changes and may even may the situation worse over time (expanding the bubble)
Most can be easily fixed with a syringe but if its widespread, that is a concern
Old Oct 3, 2015 | 09:11 PM
ChopperDan64's Avatar
ChopperDan64
If you see an air bubble after a few weeks--most likely in high contour areas--you can fix it yourself in a minute or two. Get a small foam sponge with a square corner and a straight edged razor. At the very end of the bubble, use the corner of the razor to poke a very small hole just enough to allow air to escape. Use the sponge from the opposite end of the bubble to push the air out. Use the sponge to flatten out any raised areas. After doing this and a day or two to bond with the surface in a warm area, you most likely won't be able to see it even on close inspection. I watched my installer do this and then tried it myself on another bubble I missed on the rocker. Very simple to do.
To Xpel Install
