There are paring instructions in the owners manual. I don't have it handy but I remember it's not to complicated. Requires one of the paired remotes. And you insert the non working one into the console.
Okay - I "relearned" both keys per the owners manual as recommended and still no wireless communication with the car by either key. Does anyone know what fuse to check? - it is a 2016 C7 Z06.Thanks
The car is a 7 spd manual 2016 Z06 coupe. The issue, I believe, is the car doesn't receive the key's wireless signal and I am wondering if it is the fuse. The owners manual doesn't specify the controlling fuse. Does anyone know which fuse I should check?
It will be tied to one of the body control modules and there are 7 of them. Look in your owners manual on the fuse diagrams and start checking all the BCM fuses. Also give it a battery nap for 10 mins and see if that corrects the issue. If not you need to have the dealer deal with it.
