Weight vs. Performance, Adding 100lbs
Old Oct 19, 2015 | 08:33 AM
camirocz's Avatar
camirocz
Default Who claims it is a lot faster?
Originally Posted by OVR60
The ZO6 has 200 to 300 lbs more weight and 12 more horsepower than the ZR1 and everyone claims it is a lot faster. No one mentions the weight of the driver that could also add to the total weight of the car. Remember a few years ago with Danica ?
I dont know where you get your info from but last i saw the Zr1 has a higher top speed ,trap speed through the quarter mile than the c7 z06.In fact you can watch a half mile race between the two on you tube and see how badly the Zr1 pulls away at the top end.
Old Oct 19, 2015 | 08:42 AM
Snorman's Avatar
Snorman
Scraping the splitter.
St. Jude Donor '13-'14-'15
Originally Posted by JG853
I think that member's numbers are closer than what you are saying.
My 2011 3ZR MSO shipping weight showed 3278. Mine is the "heavier" 3ZR ZR1 package. A 1ZR packaged ZR1 is lighter than my 3ZR. Thus, the lightest quoted Stage 1 Z06 coupe from what I have seen from the factory for shipping weight was 3524 (I believe). Thus, that is a 246 pound difference. I do not know how much lighter a 1ZR ZR1 is, but I would assume it could be 20 - 30 pounds, which puts it closer to 300, as he stated.
You're comparing shipping weights with very little fuel to listed curb weights.
http://blog.caranddriver.com/heavy-h...weight-leaked/
GM typically lists their lightest variants, from there, the delta could change.
GM stated the ZR1 weighed 3353#.
http://media.gm.com/media/us/en/chev...2013.tab1.html
GM states the Z06 weighs 3524#.
https://www.chevrolet.com/content/da...web_lo-res.pdf
3524 - 3353 = 171
S.
Old Oct 19, 2015 | 09:32 AM
JG853's Avatar
JG853
Go it -
The only thing is that is the ZR1 a 1ZR or 3ZR. My convertible, I will have to check the shipping weight but that is not a fair comparison to the ZR1. What was the shipping weight of your coupe?
3524 - 3353 = 171
S.
Old Oct 19, 2015 | 09:43 AM
Snorman's Avatar
Snorman
I'd have to look on the title, I'm pretty sure that Florida carries that info over to it.
S.
Old Oct 19, 2015 | 10:09 AM
JG853's Avatar
JG853
It will be interesting to see what that is on the coupe, if you have it.
S.
Old Oct 19, 2015 | 08:36 PM
2cnd Chance's Avatar
2cnd Chance
Forget shipping weight it must be curb weight.
Old Oct 19, 2015 | 08:45 PM
mirage2991's Avatar
mirage2991
1ZR here, on the race scale at the track: 3339lb, fuel fuel, all stock, no floor mats.
hope this helps
Old Oct 19, 2015 | 09:16 PM
four0nefive's Avatar
four0nefive
hope this helps
185 lb difference then. Definitely not too bad.
Old Oct 20, 2015 | 07:36 AM
JG853's Avatar
JG853
Not too bad. I will weigh my 3ZR at BlackDog Racing with a full tank of fuel and see what it weighs as well.
Old Oct 20, 2015 | 09:17 AM
four0nefive
What all do you get with the 3ZR package? I know with the 3LZ you get the heated and ventilated seats plus more leather compared to the 1LZ trim level.
Old Oct 20, 2015 | 09:34 AM
OVR60's Avatar
OVR60
Originally Posted by snorman
what does the zr1 have to do with anything being discussed in this thread?
And check your facts. The z06 is about 171# heavier than a zr1 according to gm's own numbers.
S.
the zr1 is still the king
Old Oct 21, 2015 | 07:41 AM
mirage2991's Avatar
mirage2991
for my year (2011) you got the nav (same model as the 05), powe pass seat, heated seats, leather wrap dash and upper door panels, garage door opener incorporated into the visor.
Old Oct 21, 2015 | 12:20 PM
  #33
Bill Dearborn's Avatar
Bill Dearborn
It really doesn't matter as far as the OP is concerned. He is basically interested in stop light gran prix's not even drag racing. He could add 200 lbs and not really notice a real difference in performance since there are too many other variables involved. One of those is driver skill level which is usually quite low among stop light gran prix participants.
Bill
Old Oct 21, 2015 | 12:45 PM
  #34
JG853's Avatar
JG853
You get the Nav unit, heated seats (Not ventilated). I believe you get both seats power as well (I have to check on that though as I do not recall if the 1ZR had a power seat).
Old Oct 22, 2015 | 05:48 AM
  #35
3 Z06ZR1's Avatar
3 Z06ZR1
That ZR1 has mods how about the other way stock ZR1 vs modded Z06?
Your toast! I know these cars!
Old Oct 22, 2015 | 05:59 AM
  #36
3 Z06ZR1's Avatar
3 Z06ZR1
Horsepower to weight yes any other measure NO!
Simple Halltech intake fixes the power to weight.
I really liked my Zr1 but back to back driving for 4 months.
Convinced me the Zr1 no longer was the king!
Sold and and like my new 2015 Z06 as the better driver and all around car! No question here!
Old Oct 22, 2015 | 07:51 PM
  #37
mirage2991's Avatar
mirage2991
powered on driver side only, No bolster adjustments
To Weight vs. Performance, Adding 100lbs
Old Oct 26, 2015 | 10:01 PM
  #38
RonBurgAM's Avatar
RonBurgAM
Default Insulation and Audio Info
Originally Posted by drbru001
complete, over the top, sound and heat insulation. It goes beyond what is found in the threads on this forum. I have to weigh the performance loss with the benefits of quietness and audio performance. I appreciate all the feedback. This weight is before any increase in audio gear by the way.
Doc Bru, I'm guessing you're an audiophile? Curious to hear your insulation mods in excess of what is typically done.
I would also be very interested in what electronics you are looking at. Head unit integration seems to be a challenge. And good product is heavy, A JL 10W7 weighs 30lbs.
Many of us would appreciate if you do a thread on these mods. Thanks in advance and best of success.
Old Oct 26, 2015 | 10:44 PM
  #39
OVR60's Avatar
OVR60
Did this thread turn into bash the ZR1, if the great GM comes out with something better than the ZO6 will everyone bash it also. The reason the ZO6 is slower is because of OP putting a drag on the surface causing turbulence and friction in the flow of wind across the surface. I hope someone has this useless information.
Old Oct 26, 2015 | 10:48 PM
  #40
Snorman's Avatar
Snorman
Pretty comical coming from the one who brought the ZR1 into the thread. Are your feelings getting hurt because everybody doesn't worship your precious ZR1?
Maybe take your trolling act elsewhere.
S.
