Adding stripe.
Old Oct 19, 2015 | 06:04 PM
dcher's Avatar
dcher
Default Adding stripe.
I have a shark grey Z06 2015 and am thinking of adding the carbon flash hood stripe. However, I have Suntek on my car. Is it OK or even preferred to mount the stripe over the Suntek?
Old Oct 19, 2015 | 06:14 PM
NYROBZ06's Avatar
NYROBZ06
It's no problem. My Stinger Stripe was added on top of the Suntek and mine looks great with no problems.
Old Oct 19, 2015 | 06:27 PM
dcher's Avatar
dcher
Thanks, Where did you purchase your stinger stripe from?
Old Oct 19, 2015 | 06:41 PM
BOBSZ857's Avatar
BOBSZ857
it will probably look better on top of the sun-tek. I have a factory installed stripe and if you look at the edges, you can see an slight area where the sun-tek doesn't sit flush against the hood. Almost looks like it has a small whitish pinstripe running down the side of the stinger stripe.
Old Oct 19, 2015 | 06:47 PM
dcher's Avatar
dcher
Thanks for the feedback. Sounds like its best to install on top of the Suntek. That makes life much easier. I really like the look of the carbon flash hood stripe with the shark grey exterior or any of the colors for that matter.
Old Oct 19, 2015 | 07:46 PM
NYROBZ06's Avatar
NYROBZ06
I had the vinyl shop get the material and they cut the stinger stripe and applied wrap to my top of the car. It looks amazing
To Adding stripe.
