I have a 2016 C7 Z06 w/ manual transmission. When trying to impress friends with a ridiculous burnout the car moves left/right, etc... forcing an early shutdown. What are the best settings to make extended smoke?
Just like spinning the tires on snow/ice with a positraction diff you turn the steering wheel to counteract the left right movement. Nothing wrong with the back end swinging back and forth.
It sounds like stabilitrak/active handling is shutting you down. Someone with a C7Z will come along shortly and walk you through setting it to off. Turn off all the nannies and you should be good to go.
If the road is crowned or has a sloping side you will drift left or right.
Find a nice flat area and car will stay straighter.
