I saw this covered in a Stingray forum an attempted it.The first sticker i applied a blowdryer on it for a min or 2 an when i peeled it off it came off in strips an slivers taking alot of time,the second one i just peeled up with no heat however it did pull on fAbric alittle so i would suggest getting the corners up first then pull while applyin heat.Next i used a good 30 min of sweat/scrubbing in goo gone to remove the adhesive,then i went in last with a wet towel with dawn to clean up an the other side to dry it.I will prolly hit it one more time but its close.My arms hurt,dont let anyone tell you different on that part.
