Cranks for a while before starting
Old Nov 29, 2015 | 07:33 PM
Enzom's Avatar
Enzom
Default Cranks for a while before starting
I noticed that no matter how long after I turned the motor off (5 days or 5 minutes), it seems like it takes a solid five seconds for my motor to fire up from when it starts cranking. My battery is always charged, so it isn't a battery issue. Do others notice an unusually long cranking period?
Old Nov 29, 2015 | 07:51 PM
gurneyeagle's Avatar
gurneyeagle
Isn't this a function of the direct injection fuel system pressurizing?
Old Nov 29, 2015 | 07:54 PM
Tnacdrmr's Avatar
Tnacdrmr
From what I've read it is.
Old Nov 29, 2015 | 08:11 PM
DFW_Z06's Avatar
DFW_Z06
Cruising
Mine does the same thing.
Old Nov 29, 2015 | 08:12 PM
Enzom's Avatar
Enzom
So then it is "typical" and I do not need to worry about being stranded by a bad starter motor. OK - if that's the case, then fine. Thanks.
Old Nov 29, 2015 | 08:21 PM
CONMAX's Avatar
CONMAX
Normal on all C7Z06. I drove 4 in addition to mine and they all took about 8 revs or 2s to crank before firing.
Tnacdrmr's Avatar
Tnacdrmr
Yep.. enjoy and congrats. You're not the first to voice this.
Old Nov 29, 2015 | 08:43 PM
LuckyC7Z06's Avatar
LuckyC7Z06
I wondered that also and I think its all in the function of the push button start feature. My ZL-1 I always turned key a little and let the fuel pump pressurize then cranked it and it fired right up immediately. I'm sure if GM had programmed the start sequence to wait a couple of seconds before cranking to let fuel pressure rise it would eliminate the excessive cranking. But oh well so long as it fires I'm good with it.
Old Nov 29, 2015 | 08:55 PM
ChopperDan64's Avatar
ChopperDan64
DI pump is mechanical, so it needs a few cranks.
Old Nov 30, 2015 | 08:15 AM
richie15's Avatar
richie15
I inquired about it when I brought mine in for the 500 mile service last week and was told it was normal. At least now I see that apparently it is with all the posts here.
Old Nov 30, 2015 | 08:43 AM
fpfaeth's Avatar
fpfaeth
Same thing. A year later and 14,000 miles, unchanged and no problems in any kind of weather.
Old Nov 30, 2015 | 08:47 AM
NSC5's Avatar
NSC5
This is normal for all GDI engines and it was the same thing many diesel pickup drivers wondered about when HPCR (high pressure common rail) injection was adopted for diesel engines several years before it was used for gasoline engines. The control system for the injectors is based upon having the required/expected fuel rail pressure for operation so the injectors aren't triggered until commanded fuel rail pressure is available and this takes several revolutions for the camshaft driven high pressure fuel pump to provide.
If you ever drive your Z06 in very cold weather you will notice slightly longer cranking time because with the thicker oil the cranking speed is slightly slower and it still takes the same number of revolutions for the fuel pump to pressurize the common rail system. The same will be noticed with a battery that isn't fully charged or is losing capacity.
Old Dec 5, 2015 | 11:25 AM
oneibandit's Avatar
oneibandit
6th Gear
I have notice that when I put my car in tour mode and left it over night and started it the next day and seemed a lot easier to crank. Then I put it in sport mode and it was harder to crank. Give it a try and see if it makes a difference.
Old Dec 5, 2015 | 11:39 AM
Bill Dearborn's Avatar
Bill Dearborn
OP: It all depends on how fast the starter is cranking the engine. If it is slow then you might have an electrical issue. However, if it spins the engine fast (mine spins the engine faster than any other car I have ever owned except for ones where I had the spark plugs pulled) then there is no issue with the starter.
Bill
Old Dec 5, 2015 | 12:03 PM
mikegaan's Avatar
mikegaan
The DI does require building up fuel pressure, but:
"(...after 5 days or 5 minutes), it seems like it takes a solid five seconds..."
If the quote isn't an exaggeration, I'm not sure that's normal. If I've run the car, then parked it for a while (e.g. at a restaurant...hour or two), it fires right up. Also, mine never takes 5 full seconds to crank, even after sitting for a week...maybe 2 or 3.
FWIW.
Old Dec 5, 2015 | 12:10 PM
JackTripper's Avatar
JackTripper
Turn 12!
Mine does the same.
Old Dec 5, 2015 | 01:14 PM
Jus Cruisin's Avatar
Jus Cruisin
I look at it being similar to how I've started my cars that don't need a key. Roll the starter for a few seconds and then hit the ignition. The Corvette might get the engine turning over for a few moments before lighting the ignition.
To Cranks for a while before starting
Old Dec 5, 2015 | 01:43 PM
NSC5's Avatar
NSC5
It should not take 5 seconds but unless you are accurately timing it you may be misjudging; few people can accurately judge short periods of time.
From GM the following are expected start times:
Above 50F may take up to 1.5 seconds
From 14F-49F up to 2.5 seconds
Unless the ambient temperature is -4F or colder it should not take 5 seconds.
If your engine is exceeding these times then either the cranking RPM is low, the high pressure fuel side of the system isn't building pressure properly, or the rail pressure sensor is returning a false low reading. IN any case if your time is outside of those specified it is time to see your dealer.
Old Dec 5, 2015 | 05:18 PM
Enzom's Avatar
Enzom
Thanks. I will time it today
Old Dec 5, 2015 | 06:02 PM
ChopperDan64
I was experiencing this same issue and we "think" it is the high pressure fuel pump not pressurizing the rails because it is dumping fuel into the oil. Since we are still two weeks into waiting on a pump, not really had a chance to diagnose. There is definitely fuel in the oil. I think my car is a freak issue, but I'd keep an eye on your oil level. Check per the owners manual. You need to warm the engine then wait 5-10 minutes.
