AFE intake Problem and no help from them
Old Dec 7, 2015 | 11:28 PM
BigNastyZO7's Avatar
BigNastyZO7
Default AFE intake Problem and no help from them
The intake when on hits the top of hood, Since then it has been removed and luckily the damage it did to hood I was able to correct. I see there is a newer redesigned style? I'm guessing corrects this problem? The reason I'm asking on the forum is because I am NOT getting my emails/calls returned on correcting this deffective part. Anyone else experiencing this issue? I will give it a little more time before making the next step.
Old Dec 7, 2015 | 11:42 PM
NORCAL-SS's Avatar
0NORCAL-SS
Former Vendor
When did you get the intake? I can help you contact who you need to talk to
Old Dec 8, 2015 | 12:03 AM
LuckyC7Z06's Avatar
LuckyC7Z06
I just installed this past weekend and it fit perfectly.
Old Dec 8, 2015 | 01:01 AM
sdtoothdoc's Avatar
sdtoothdoc
I had a hell of a time with fitment, being one of the first to get the AFE. Running the hose above the intake caused rubbing. I imagine many just install, slam their hood, and assume all is good. Not sure if they redesigned it or not, since I returned mine for a full refund. I also noticed no gain in performance, and even could hear audible knock in 8th on the freeway. Didn't notice once I switched back to stock. Halltech on it now with no issues.
Old Dec 8, 2015 | 04:36 AM
Fastmikefree's Avatar
Fastmikefree
Yep a piece of hose for coolant is now included, same as Halltech. They both had the same issue. It is better to install it even if some people were able to run the original ones according to some posts on this forum.
Phil
Old Dec 8, 2015 | 05:34 AM
BigNastyZO7
AFE Power (Josh) Thanks Tony I greatly appreciate it
Old Dec 8, 2015 | 06:48 AM
HC-C7's Avatar
HC-C7
A picture would help and make sure any hoses from the drysump or radiator don't sit on top of intake box but along side it .Otherwise you will have issues closing the hood.
Old Dec 8, 2015 | 06:51 AM
BigNastyZO7
I ran the hoses underneath the intake for a cleaner look! Good thing as it would rub even more woth hose above intake
Old Dec 9, 2015 | 11:22 AM
aFe POWER's Avatar
0aFe POWER
Former Vendor
We tried to contact you yesterday in regards to your intake being taken care of, if you have any questions or concerns regarding our parts feel free to give us a call at 951-493-7100.
Old Jan 21, 2016 | 06:21 AM
Fastmikefree
As usual GREAT support form AFE Team!!!
Phil
To AFE intake Problem and no help from them
