Changing plugs
PID2476: MISFIRE! Call The EPA! MISFIRE! AEEEIIIIEEE!!!!!
(or something similar)
Am I exaggerating? Only on the text. The cam/crank position sensor package actually can monitor the acceleration and deceleration of the engine through its rotation and know when one cylinder didn't help as much as the others. Pretty simple and elegant if you think about it.
By the time YOU think there might be a miss, the computer knew about it long ago. If the computer doesn't think there's a miss, there's no miss.
(Power loss) at WOT at somewhere between 80-100 mph. However there are no codes or check engine lights. Going to another dealer on Wednesday.
While this is supposed to be the way it works in my experience it doesn't always set a code.
The PCM does exactly as you stated but a misfire code may or may not be set with a misfiring plug. While I am fairly certain if the plug or wire is totally bad the PCM will probably set a code. But one that is marginal that "blows out" under high boost or high rpm (under load) and then subsequently returns to normal under light load, low boost and/or low rpm may not be not set a misfire code.
I chased a stumble on my LS3 for weeks because I put to much stock in not having a misfire code. Had the same issue on a friends super charged LS2 and several LS1's over the years.
I found the issue by reading the plugs the first few times this happened. But was curious as to why no code was set or if the PCM saw the misfire at all. I read the PCM data log. The PCM algorithm was catching the misfires on each individual cylinder so I compared them all and learned that (on my LS3) my good plugs where firing at 92ish %. The bad plug was firing at 76%. Firing normal at idle and cruise but missing at high RPM WOT. And no code. The cylinder balance test didn't catch it either.
I know the E92 PCM has GM's most advance technology and should be better at misfire than the older PCM's but my past experience tells me that under boost, high rpm or any other time cylinder resistance is high, you may not be able to depend on the a code being set. As with so many intermittent issues you may need to dig a little deeper.
Regardless reading or changing the plugs and checking the resistance of the wires is a cheap first step to resolving a miss or stumble. With a boosted car marginal plugs can misfire under boost and not set a misfire code.
Point is if its a misfire you can duplicate it in any of the higher gears. A8 or M7 hold the engine at WOT in a gear 1, 2 or even 3 gears above the one you are normally seeing the suspected misfire (4th,5th or 6th gear). The goal is to load the engine under boost but not sweep through the rpm range to fast. This creates high cylinder resistance and high torque with a slow sweep through the rpm. This can be done safer and at slower speeds and a misfire will show up. If it shows in other gears its likely a misfire. If not and it happens at 80-100 mph regardless of what gear then it is not.
With current ignition systems this is less important. For me, it is mostly an old habit that made a couple of tenths difference years ago.
absolutely no doubt
