Gents,
My long range plans is to get the Lingenfelter Stage 1 Mod. In the meantime I purchased a Trinity to eliminate CAGS, improve throttle respond (Throttle Boost), and increase % of fans. My question is those of you who installed the 91 octane tune...was it noticeable over stock "did you get a seat of the pants feel," car pull stronger? Thank In Advance!
v/r
THEYAV
jdmdohcpower,
Did you increase the "throttle Boost" in your tune. It will really wake up throttle responce. The trinity tune has it included however there is an option to incresase it another 20%. Thanks for the advice on the haltec.
v/r
THEYAV
If you didn't promise not to, if someone wants to send me their tune I can compare it to the base tune and tell you what they actually did. That would presume you have a way to get the tune out of the ECM, however...
Did removing the CAGS function by tune eliminate the 1-4 dash light?
My recollection from my '14 is that it does eliminate the light as it was different than the CAGS plug I had in 3 of my previous GM manuals. Makes sense that it does as the function is deleted in programming.
