Sponsored by: GEM Motorsports
Thoughts on DA and 60 ft
Old 02-14-2016, 06:43 PM
moon2605
moon2605's Avatar
Default Thoughts on DA and 60 ft
just left the drag strip. it is an 1/8 mile track. i am extremely green when it comes to drag racing ( learning though). i do have some mods and drag radials. tires were sticking like glue. a8 car. best time was 1.71 60 ft, 7.02 1/8 mile. i used launch control on most passes. did a few passes without launch control and had about the same results. i expected better. da was 1576 . would the da make a reasonable difference or is it simply my inexperience?
Thanks,
Kevin
Old 02-14-2016, 06:52 PM
JMB
JMB's Avatar
What was your MPH?
Old 02-14-2016, 06:58 PM
fleming23
fleming23's Avatar
2020 Corvette of the Year Finalist (track prepared)
C3 of Year Winner (track prepared) 2019
Seems pretty on par with this car
https://www.corvetteforum.com/forums...drag-race.html
Old 02-14-2016, 06:59 PM
moon2605
moon2605's Avatar
Originally Posted by jmb
what was your mph?
104.36
Originally Posted by fleming23
i agree but i see a lot better times on the forum. may just be lack of experience
Last edited by Steve Garrett; 02-14-2016 at 09:36 PM. Reason: Merged Posts-please use the Multi-Quote button (middle icon) in the right hand corner of each post.
Old 02-14-2016, 07:12 PM
Fore58
Fore58's Avatar
Originally Posted by moon2605
104.36
104.36 is fast
Old 02-14-2016, 07:15 PM
davepl
davepl's Avatar
Received 1,500 Likes on 987 Posts
Using a 1/4 from 1/8th mile conversion calculator:
Your 1/4 Mile ET is 11.05 seconds computed from your vehicle 1/8th ET of 7.02 seconds.
Your 1/4 Mile MPH is 129.41 MPH computed from your vehicle 1/8th MPH of 104.36 MPH.
So, sounds like it would be good for 11.05@130 roughly. You'd need a 6.98 to break into the equivalent of 10s, and that's not far away!
Old 02-14-2016, 07:30 PM
Thomasmoto
Thomasmoto's Avatar
Received 1,505 Likes on 1,027 Posts
Default Z06
Originally Posted by Fore58
104.36 is fast
I agree. Great mph. My last 1/8th was a 6.98 @102.59 mph with a 1.60 60'. You will improve with seat time. I've been drag racing 37 years.
Old 02-14-2016, 07:42 PM
moon2605
moon2605's Avatar
Thanks. i guess i just need to practice. have to get 60 ft down
Old 02-15-2016, 12:59 AM
C7/Z06 Man
C7/Z06 Man's Avatar
Default Kevin
Don't know if true or not but a member posted that an 875 change in DA is worth a tenth/1mph in the 1/4 one way or the other.
JMHO:
If your sticken then better air will improve overall power which will improve everything including 60 fts. Also If your sticken I feel "not" using the launch control will improve 60 fts. more. Try a 2200 launch to begin with, than experiment up and down some to see what works best for you. Also roll in enough to "just" light the second stage bulb for best 60 fts.
Oh, I have never tried this myself but sometimes due to weather, gas, etc. your computer may of reduced/pulled performance, so disconnecting the battery for a minute or so will re-boot the computer which may improve performance. May be worth a try, up to you.
I like track mode with one push of the center button to just turn "traction control" off in "D" with my A8.
You should list you mods, you may get some more suggestions.
EDIT: It has been my experience that the calculators with pressurized cars are not always right on, just look at the posted time slip in this thread. All things considered that 104 mph is hauling a$$.
Old 02-15-2016, 07:36 AM
moon2605
moon2605's Avatar
JMHO:
thanks. Mods are dr, cai, meth, tune, headers, heat exchanger and tank.
Old 02-15-2016, 11:45 AM
JMB
JMB's Avatar
This is a good MPH for a slightly modded car @ 1500+ DA. My estimate for your car @ zero DA would be low 10's @ 137+MPH! Hang in there......at 1500+ DA you should be able to get that car into the mid 10's in the 135 MPH range, good luck!
Old 02-15-2016, 11:47 AM
moon2605
moon2605's Avatar
Thanks. That's what I like to hear. We will be at a quarter mile strip next Saturday. hope to see some 10s.
Old 02-15-2016, 11:58 AM
ZoratZ06
ZoratZ06's Avatar
Just my opinion, but I'd say given your 7.02 1/8mi time and the MPH of 104+, that run would've definitely been in the 10's. The time slip listed above ran a 7.04 (slower) and 100mph (slower) and ran 10.9s. I'd say you're probably running 10.7 to 10.9s. I have an all stock M7 and have run 11.4 (DA 2350) so far and my 1/8th time was 7.52s at 98mph.
You're 1/2 second quicker and 6mph faster...so it's extremely reasonable to think you'd take .5 to .7s off of that time. I know DA plays a big roll...but it looks like you already have an 'easy' 10s car...Slightly better launch, better DA, I'd say mid to low 10s. Just my opinion though.
moon2605 (02-15-2016)
Old 02-15-2016, 01:09 PM
JMB
JMB's Avatar
Perfect, I'll be rooting for you and waiting to see the results!!!
Old 02-15-2016, 03:01 PM
C7/Z06 Man
C7/Z06 Man's Avatar
Yes, please post your results here. If you didn't throw ice in the tank last time I would this time.
Old 02-15-2016, 03:05 PM
Thomasmoto
Thomasmoto's Avatar
I'm going to Orlando Speed World this coming Saturday and hope for some 10 sec slips as well. They are having a big night street car race, so DA should be pretty good. I'll post as soon as I can.
Old 02-15-2016, 03:15 PM
C7/Z06 Man
C7/Z06 Man's Avatar
I've had my eye on you for awhile now!
To Thoughts on DA and 60 ft
Old 02-15-2016, 03:53 PM
moon2605
moon2605's Avatar
Any mods?
Old 02-15-2016, 08:13 PM
LS1LT1
LS1LT1's Avatar
As others above have stated, it's probably a combination of both.
But yes, DA can definitely have an effect on sixty foot times...a lower DA should definitely help lower that sixty foot (and ultimately ETs) a bit. The unfortunate part is, a really really great DA can also potentially hurt your sixty foots as well. In my area two days ago, the DA was roughly -4500 which sounds good 'on paper', but the -10 degree temps that came with it sure would make finding any traction a real chore in a 600+rwhp Corvette LOL. So there is of course 'a point of diminishing returns' so to speak.
Old 02-15-2016, 08:43 PM
Thomasmoto
Thomasmoto's Avatar
Default Z06
Any mods?
Nope 100% stock and drag radials.
Quick Reply: Thoughts on DA and 60 ft
