I'm sure Fred can make them longer if you ask him. I've never had good luck keeping the foam protectors on and I'd be worried about them melting against warm to hot rotors.
Can you send this picture to Sciom in Germany?
His email is: info@sicom-europe.com
If you can email him the pic he will let you know if it is acceptable or not.
I just sent out my rotors to get refurbished.
I think you should be okay to run them.
The ones I had large chip marks with gouge marks in them.
I sent the pic to Sicom in Europe per your suggestion and got the following response from Wolfgang Dietz:
In my opinion it is OK for driving. But to be sure you should invest 900€ to fix it properly. Brakes and tyres are not forgiving.
Sounds like Sicom offers a repair / refurbish service for the CCB.
Where did you (vettekid05) ship your rotors ? Europe ? Any details ? Cost, etc?
Refurbished??? Please explain. Is this for minor damage? I have pocked rotors that are within the weight spec but have experienced evaporation, curious as I thought these were toast. Thanks
Maybe we should take offline, but what is evaporation damage? can you elaborate? My car is 5 years old, low miles, made about 10-12 high speed stops and I see no degradation in the CC rotors.
Carbon brakes do not wear like normal rotors. The resins that hold the rotor together evaporates. Once the brake gets below a certain weight they should be replaced. Your car will be no where near that threshold.
I believe the permissible weight is stamped onto the rotors...the conventional thinking is that for street-use, the CC rotors could last the life of the car. Repeated track use with a series of high-temperature braking/stopping will necessitate removing the rotors periodically to have them weighed.
Yes your carbon rotors can be refurbished. I sent out my rotors to Sicom in Germany to get done. You can get a good deal from him. I think you can get them done 2-3 times over. I heard that when they get done they are better than oem.
If you aren't tracking your car, the rotors will probably last a lifetime. Mine were like brand new for 5 years with much more use, then degraded after tracking. Once you reach those much higher temps the carbon evaporates causing pocking or a rough surface. Thats why you have to weigh them to see if they are within spec.
I had read that before in another thread sometime ago, but forgot it.
Just for a frame of reference, how much "tracking". A couple of HPDE events, or ten, how many 20-30 minute sessions? Just trying to get a feel for the CC rotors durability.
I remember reading in the ZR1 section a few posts by members regularly tracking their cars (HPDEs) indicating they would go through
three or four sets of CC pads and then have to change the CC rotors. A set of pads might last three--four HPDE days (4 sessions per day)
with a very skilled & experienced driver ?
Running standing 1/2 mile or mile events doesn't generate nearly as much sustained heat on the pads/rotors as road course work...
EDIT: see some comments in this thread about CC pad life by current CCB users...
I did 2-3 HPDE events in 4 years and all was well. 25 min sessions. Then I did 4-5 in one year the evaporation had started. Seems to be about 4 HPDE = a set of pads also. The rotors are very robust but seem to only really degrade if tracking. There is a threshold temp that starts the evaporation. Most never reach that unless tracking. Milkyu and WERKs both have a lot of experience with our rotors. Milkyu has switched to Iron rotors for tracking.
