DSC-Sport suspension pricing released and Katech pre-order started
Is the only difference between this and the OEM solution is that it can be programmed? Can you store multiple calibrations?
Premium Supporting Vendor
Yes, to the limit of the shocks. That is why the next level is a shock upgrade. Not only can you firm it up, but you can map it in different areas based on vehicle speed, G-force, shock velocity, throttle angle, etc. So it can be soft up to a certain point and then firmer. So you could say I want it to be softer than stock up to .5G cornering and then firm up. Or based on shock velocity to handle potholes etc..
The tuning possibilities with this controller and software are pretty mind blowing. I told Mike that I like Sport mode but I wanted a softer ride with it like Tour.
Rather than soften it up all we time we just plugged in a bigger "hole" in the center of the G curve. So in my case as long as the car is seeing less than .2 Gs the shocks stay very soft. Throw it in to a curve though and firms right up.
4GS7 (02-26-2016)
Yes, you can firm up the front shocks in the negative portion of the G table. You're probably pushing the limit of the stock shocks though so you would benefit from the RT shocks.
Check out the software tutorial on youtube that Jason posted in his initial post. In the software you have 3 calibrations to work with and they map to Tour/Sport/Track. You read the current config from the controller, make your edits, and then upload them back to the controller.
You can download the software here and play with it.
http://www.dscsport.com/software/
And I assume this doesn't affect any of the ptm tc or sc. Eco mode and weather still work as normal?
Received 3,887 Likes
"Ask Tadge" Producer
...assuming the front tires have enough grip to deal with it, of course. That weight transfer is going to go somewhere, and if it's not absorbed by the shocks (via compression), it just means it's transferred to the tires.
I had TPC Racing/Mike Levitas install the DSC controller and RTx shocks on my 2010 911T race car over the winter racing season break.
The PCA Sebring race several weeks ago is the first time I’ve had it on track since the install. The DSC system transformed the car. It’s hard to describe the improvement realized with the system. I have been running high end JRZ shocks well tuned/set up for my car prior to the DSC controller and RTx shocks
First session right off the truck after not driving all winter and prior to fine tuning/tweaking the system I knocked over 2 seconds off my prior best time at Sebring. For those that have raced/driven Sebring it is a VERY rough/bumpy track. The DSC system literally made the bumps disappear. It was like driving on a freshly paved highway. Just truly remarkable.
I did a bunch of research prior to committing to the system. Several years have been spent developing the system on race and street Porsche's with impressive results. A 997 TPC Racing IMSA Porsche Cup race car was the test mule. The 997 Cup car ran faster lap times than half the field in newer generation 991 Cup cars!!! Lots of discussion on Rennlist on the DSC system. I've not read a single negative post. Everyone who's bought the system posts impressive results.
They then developed the system for the Viper with the same positive results as on Porsche's. The Viper forum guys also praise the system.
Based upon the years spent developing the system I'd be surprised if the same results realized on Porsche's and Viper's aren't seen on the Z06.
The quality of the shocks is second to none. They are suspension **** and it's a shame they're hard to see once installed.
I started my research here: http://www.dscsport.com/ and then read hundreds of posts found Googling DSC Sport. Lots of info out there. Here's some useful info:
http://arstechnica.com/cars/2015/07/...cks-in-action/
http://rennlist.com/forums/997-gt2-g...ion-forum.html
I've no vested postion with DSC but am an extremely satisfied customer. Game changing.....
thebishman (02-27-2016)
#34
This looks really cool. Is the idea that there will be canned or default suspension calibrations we would start with? Right now the faculty MRCS has different calibrations depending on if a non-Z07 has or doesn't have the aero package or CCBs. Would the canned tunes be generic enough to apply to all the possible factory combinations?
#36
That might sound complicated but it's fairly easy.
Point being, the calibrations are straight forward and usable for different shocks -- I'll post some screen shots later (not on my PC).
#38
#39
I could also upgrade my FE6 dampers with FE7 and the corresponding bushings, etc. The key thing would be to know what the OEM FE7 values are to start with.
Can the DSC software read the OEM controller?
#40
From what I understand, the stiffer rear bushings were to add a bit of balance to the car due to the stiffer front spring. It was cheaper to put in stiffer rear bushings than a stiffer rear spring or rear stab bar. The car was probably prone to understeer with the same FE6 rear stab bushings. The bushings effectively raised the sprint rate of the stab bar.
If you were going to change springs out, you are probably much better off going with coil-overs. This setup takes you way past an FE7 car, so no reason to bolt on FE7 parts - especially because coil springs are not going to be materially more money than OEM FE7 leaf springs.
If you want to adjust stab bar rates, you are probably better off buying an adjustable set of stab bars and starting there.
As far as calibrations go, the DSC module is light years ahead - and it's not really like they are a 1:1 match. The DSC adjusts all dampers independently and adjusts them based upon many more factors than the OEM controller.
**EDIT**
Sorry I just re-read your question.
Yes, you could definitely upgrade the dampers to FE7 dampers, then get the springs and bushings. When I was doing the numbers, the dollar amount was around $2,200 for OEM parts.
You could do this in stages, as I don't now how much more effective the FE7 dampers would be -- you could start with springs and bushings, and then see where you were at. I'd hesitate spending $1,600 on OEM dampers if you can avoid it. Total cost of ownership on the Tractive DDA dampers is probably similar - $4,900 for the dampers, could resell for $2,500 or more, vs. OEM FE7 dampers being mostly worthless.
