Sponsored by: GEM Motorsports
NORCAL SS C7 Z06 Gauge. 1 gauge does it all.
Old 03-13-2016, 04:20 PM
0NORCAL-SS
Former Vendor
NORCAL-SS's Avatar
Default NORCAL SS C7 Z06 Gauge. 1 gauge does it all.
After months of working on the programming its finally ready and comes with the install bracket. I wanted to make a oem looking set up since I really dont want to see a gauge on my dash or pillar
Heres the order link $289 SHIPPED WITH BEZEL
http://c7z06owners.com/store/norcal-...tom-gauge.html
This gauge is a bolt in deal monitors a lot of the cars points and even has a option of the alcohol percentage for e85 users. Best of all you can turn on the intercooler pump to cool down the blower when car is off and it shows IAT 1 TEMP as well as the IAT 2 TEMP as well. I also offer a wideband kit for it with a bosch sensor so that is another plus. I can do the gauge digital display in red/blue/green also.
As for gauge finish options. I can offer a carbon fiber background and ring as well as a black ring and a black line machine face ring as pictured below. The bracket that holds it in the cubby hole presses right in and holds is snug and powdercoated black. You will just need to make a small hole on top of the cubby which is hidden to run thru the wire.
Any questions feel free to ask im around 24/7
for install you will need to take parts of the dash apart which is no big issue and can be seen here
Mikec7z (03-14-2019)
Old 03-14-2016, 10:41 AM
WzUpDoc
WzUpDoc's Avatar
I assume the OBD access under the steering column remains viable and this is giving someone a second access point
Old 03-14-2016, 11:28 AM
0NORCAL-SS
Former Vendor
NORCAL-SS's Avatar
It plugs into obd port. Pops right out if dealer needs to scan ecu or doing a tune. Also the wideband can be hooked up to hp tuners or efi live
Old 03-17-2016, 01:06 PM
MIGHTYM0USE
MIGHTYM0USE's Avatar
looks great!
Old 03-17-2016, 01:25 PM
0NORCAL-SS
Former Vendor
NORCAL-SS's Avatar
I've been getting great feedback so far. Sitting in the lanes and being able to turn on the intercooler pump is a major benefit.
Old 03-17-2016, 01:30 PM
0NORCAL-SS
Former Vendor
NORCAL-SS's Avatar
Airbag on pillar iirc. Plus would need to do new pillar mold
Old 03-17-2016, 03:45 PM
0NORCAL-SS
Former Vendor
NORCAL-SS's Avatar
pod on coulum would block cluster to much already tried that. plus the gauge can record your run and has leds that flash when your parameter setting goes higher or lower than what you set it to. no missing that
Old 03-17-2016, 09:13 PM
DRLC5
DRLC5's Avatar
Looks great, this is like the one I think you sold for the CTS V?
Old 03-17-2016, 09:19 PM
0NORCAL-SS
Former Vendor
NORCAL-SS's Avatar
Yes but z06 programming is way different
DRLC5 (03-18-2016)
Old 03-18-2016, 08:33 PM
RandomTask
RandomTask's Avatar
I'm surprised no tuner has 'hacked' the digital screen yet; there's got to be a way to reprogram that thing. . .
SpeedyD (09-22-2016)
Old 03-22-2016, 12:11 AM
0NORCAL-SS
Former Vendor
NORCAL-SS's Avatar
Also can pop up the red leds whwn you set a parameter like If iats get warm or shift light
Old 04-05-2016, 11:51 AM
0NORCAL-SS
Former Vendor
NORCAL-SS's Avatar
First batch of 25 gone. I will update when I get more in
Old 04-27-2016, 01:30 PM
0NORCAL-SS
Former Vendor
NORCAL-SS's Avatar
Back in stock
Old 04-27-2016, 03:41 PM
Poor-sha
Track Rat
Support Corvetteforum!
Poor-sha's Avatar
Received 3,400 Likes on 1,372 Posts
Since you're able to pull both IAT1 and IAT2 can you see which value the Aim Solo is pulling for IAT? Since you can't run both at once I guess you'd have to switch which is plugged in to the OBD II and compare values.
BTW, looks like your domain expired so the order site isn't available.
Old 04-27-2016, 04:03 PM
0NORCAL-SS
Former Vendor
NORCAL-SS's Avatar
You can look up to 8 different parameters that scroll. I usually have oat 1 and 2 along with oil and knock going
Old 04-27-2016, 04:09 PM
bradgto
bradgto's Avatar
Had these on in my 04 GTO .. i had the dual thou. They were awesome.. Love that someone has made them work with the Z06.. thumbs up sir!!!
As soon as my mod bug hits me I will be ordering these. Any chance of the dual working on these cars?
Old 04-27-2016, 04:31 PM
0NORCAL-SS
Former Vendor
NORCAL-SS's Avatar
Yes I would hsve to make a dual plate for pods
To NORCAL SS C7 Z06 Gauge. 1 gauge does it all.
Old 05-06-2016, 07:58 AM
0NORCAL-SS
Former Vendor
NORCAL-SS's Avatar
warmer days coming up. For those that drag race my set up can turn on the IC pump to cool the car down when in staging lanes WITHOUT the car having to be turned on.
Old 06-06-2016, 11:01 AM
0NORCAL-SS
Former Vendor
NORCAL-SS's Avatar
Bump to top
Old 09-22-2016, 05:42 PM
marc0779
marc0779's Avatar
Default E 85
Will this read e 85 content?
Quick Reply: NORCAL SS C7 Z06 Gauge. 1 gauge does it all.
