Comp Seat Conversion
Old Mar 25, 2016 | 01:39 PM
BWFitz's Avatar
BWFitz
Default Comp Seat Conversion
Just got my entry confirmed for the Nevada Open Road Challenge this May. Safety requirements for the 125 MPH class meant I needed to change the sport seats to Competition seats so that the shoulder belt angle was correct and the belts did not get pinched together as they do by the stock seat. Thanks to the good people at Suburban Chevrolet (Trunk Monkey) the seats will now pass tech and I am a happy man! Hope to see some of you in May and/or September. This run is a real kick!
Old Mar 25, 2016 | 02:31 PM
Bill Dearborn's Avatar
Bill Dearborn
Is there any difference in the stiffness/thickness of the seat bottom foam from the GT seat to the Comp Seat?
Bill
Old Mar 25, 2016 | 06:59 PM
Poor-sha's Avatar
Poor-sha
Track Rat
Yes but I assume he did what I did and converted the seat backs. The comp seat bottom has stiffer foam.
Old Mar 25, 2016 | 07:43 PM
subchev's Avatar
0subchev
Former Vendor
I'm glad we could help you out!!
Since the foam is roughly 20% denser than the base GT seats, it gives a great advantage only converting the seat-backs and not the bottoms to keep the comfort aspect while ensuring resiliency!!
Corvette C7 GM Competition Seat Conversion
Old Mar 26, 2016 | 02:47 PM
BWFitz's Avatar
BWFitz
Bill
Yes. The GT seat foam is thicker. That is why my Z was ordered with the GT seats not the comps. I changed out the backs only just to pass tech..
Old Mar 27, 2016 | 07:24 PM
RACE U's Avatar
RACE U
From: Louisville Ky NCM Lifetime Member 429 (Member Since 1993)
St. Jude Donor '12-'13, '16
Would be interesting to see the whole seat in picture.
Also, do the comp seats push in more (from the sides) than the GT seats? I am a very big guy, and could stand any more pressure in the bolster arae.
Old Mar 27, 2016 | 09:32 PM
lgodom's Avatar
lgodom
Yes they are definitely tighter in the seat back bolster and in the seat cushion sides. If you have a larger frame I'd stick with the GT seat. The seat cushion is the same dimensions but the firmer foam changes the feel quite a bit. You sit more on top of the seat vs sinking in. I'd like a seat with the GT back, comp seat bottom foam, and the GT seat bottom side bolsters.
To Comp Seat Conversion
