Insulation mod
Old Apr 8, 2016 | 07:40 PM
3 Z06ZR1's Avatar
3 Z06ZR1
Default Insulation mod
I like the car more quiet. The tire noise is pretty bad so I have put on
Michelin SS non runflat and got some noise relief but not real major like on the C6 ZR1 and Z06.
So I looked under the rear carpet and found empty under the carpet.
The insulation that was there was on the sides nothing in the middle. Nothing but the carpet so I used some 3/4 inch thick car insulation. Actually from my 2006 Z06 left over they had a factory insulation pack you could order.
The 2006 car came with 2 bags from the original owner.
I put a put a large square about 30 inches by 36 inches under the carpet cut to fit in the missing area.
Wow! After a few hundred miles. Was I'm happy to report it is noticeably less noisy from the tires in the interior. Music sounds better too!
Well worth the small effort!
Now I think I will go back and some more around the battery area.
Old Apr 8, 2016 | 08:29 PM
DRLC5's Avatar
DRLC5
Nice job.
Old Apr 9, 2016 | 01:10 PM
davepl's Avatar
davepl
Note that you used the correct material - dynamat would have done next to nothing in this case (he's not deadening a panel, he's insulating against sound transmission). Where'd you grab it, just at Home Depot or a carpet store, or is it high density auto specialty, or ???
My solution was to buy a convertible, you can't hear any of that stuff!
To Insulation mod
