Z06 maximum width?
Old Apr 22, 2016 | 05:34 AM
spearfish25's Avatar
spearfish25
Default Z06 maximum width?
While awaiting my Z06 delivery I've started wondering if it'll fit on the single door side of my garage. While the specs list a width for the car, I'm not clear if that's a mirror to mirror width or just the body excluding the side mirrors.
Would one of you guys mind measuring the maximum width from side mirror to side mirror? Do those mirrors power fold?
This will become very interesting if I can't fit it on 'my' side of the garage.
Old Apr 22, 2016 | 07:54 AM
NSC5's Avatar
NSC5
The mirrors fold manually. I measured just over 85" with the mirrors out so it will fit through an 8 foot door (typically 92-93" finished width) but depending upon orientation you may have to back in to make sure you have room to open the driver's door enough to get in and out.
When I brought my Z06 home my Cadillac ATS moved to the 8' stall where it fits easily and my Z06 and GMC 2500HD crewcab have the 9' slots.
Old Apr 22, 2016 | 08:01 AM
spearfish25
Thanks! I'm at 92" for the stall so good to go. Definitely backing in.
Old Apr 22, 2016 | 10:31 AM
ZR1Bob's Avatar
ZR1Bob
I too was surprised by the width--the tires hang about 1" over the edge of my Direct Lift PP8S on both sides when it is lined up perfectly. The old 95 ZR-1--also a wide car--had both tires well inside the outer edges of the lift. --Bob
Old Apr 22, 2016 | 11:33 AM
jaden61's Avatar
jaden61
2017 C7 of the Year Finalist
My door is 94" mirrors have about 4" each side.
Old Apr 22, 2016 | 11:41 AM
spearfish25
Cool thanks! I should be fine then. Now I just need the car. I'm like a 3 year old being told to wait.
Old Apr 22, 2016 | 11:49 AM
Edwardz's Avatar
Edwardz
Good luck! This is such a awesome car.
davepl's Avatar
davepl
Pretty sure anything over 79.8" requires clearance lights, and we don't have those.
Old Apr 22, 2016 | 12:00 PM
jaden61's Avatar
jaden61
Here is some reading material for you. page 33 says it is 77.4 inches wide, I bet that is with mirrors closed though. I would think overall width would be with its wings spread.
https://www.chevrolet.com/content/da..._eBrochure.pdf
To Z06 maximum width?
