C7 overheating cure
Popular Reply
2 things.
1. Don't let all of the talk about overheating sway you away from getting a Z06. While it can occur it is fairly rare. By rare I mean if you don't track the car you will never see it. If you track the car if you are capable of working the car really hard you might see it if its above 80ish degrees outside. Other wise you will never know the problem exist.
2. The overheating in the Z06 isn't the engine over heating it is the transmission or engine oil temps reaching their limit. Water injection would do little to help this.
DeWitts has several things they are offering including replacing the oil cooler with an oil to air cooler, replacing the radiator with a larger radiator and a larger intercooler.
If you don't track the car none of this is your concern. The cars do not overheat on the street or highway and they do not lose their performance although it is doubtful anybody would ever know based on seat of the pants experience.
If you want a Z06 for the street there is no reason other than lack of money not to buy one. Overheating isn't even a consideration.
If you want to track it you need to observe the oil temps and make sure you keep them under control. However, some people run the hell out of the cars for a half hour and never see an oil temp warning.
The C7 Z is one bad a$$ car and it has the performance to back it. Two weekends ago I was at an HPDE at VIR where they had a Ferrari Challenge Race. The lead Ferrari's were running 1:57 lap times. These are full race cars with cages, stripped and lightened as much as rules would allow. A guy who had recently purchased a used C7 Z06/Z07 came to the event on Saturday. He didn't know how to set the car for the track and was complaining because he was turning 2:05 lap times and the traction control was holding him back. I told him how to get into track mode and about the 5 settings. He chose Sport 1 which has some stability control at the edge and PTM. After the next session he told me he was turning 2:01s with just that one change. The car was completely stock, it didn't even have race harnesses.
There is a member on this board that gets 1:59s on his basically stock car. Not bad when compared to a full out race prepped F430 that turns 1:57s.
Bill
2 things.
That being said water injection has been used for years in aviation (since WWII) and in cars (in the 60s Oldsmobile's f85) to suppress detonation. I used it in the 80's with both water and alcohol to run additional boost in a 300zx turbo. It certainly works.
I am sure it could help the Z06 as well. If anyone ventures down this path just make sure to use a quality system that's well thought out for this application. Back in the day when I was playing with it, a good reliable system was hard to find and fairly expensive. With todays technology it should be a piece of cake. Otherwise WI/AI can be a headache.
2 things.
Bill
DATA: Four 20 minute sessions / 82-87 degree ambient / 98-104 on track temps / Advanced group driver at full speed / 670 rwhp /oil temps never over 207 (prior 270) / coolant temps highest degree was 219 (prior went into limp mode after 245 and two laps) / Each session was between 12 and 15 full laps / car never skipped a beat and everyone there that owned a Z06 wanted to know how and how much.
It is your choice to add extra cooling capacity but you should base the decision on how you plan on using the car. Have you ever participated in an HPDE? When you say you doubt you will do much tracking do you really mean you will not do it?
There are a bunch of solutions being offered by GM and aftermarket vendors. Some are lower cost than others some require a lot of labor to install and some don't. All involve at least a minor mod to the car and maybe some risk from a warranty standpoint if you have a failure that is attributable to the mod or to the installation of the mod.
For instance, Tadge has said if you install the GM Secondary Radiator it will not impact the warranty but he didn't say anything about what would happen if the installation of the secondary radiator was screwed up and caused a problem. Leaving the car stock for street driving means even if the engine melts down to a molten block of aluminum under normal driving circumstances in the US and you didn't abuse it the warranty will cover the replacement.
Once you install any mods or open the engine in any way you raise questions. If an issue isn't going to affect you in any way because you never see the conditions that raise the issue do you really want to spend money to assume added risk you don't need to assume?
Bill
It depends how you shift it. If you shifted the M7 as aggressively as the computer shifts the A8, you'd heat up the exact same.
It's not the trans that's making the problematic heat, it's the engine being held at higher RPMs that is doing it.
Similarly, if you shift the A8 like an M7 driver, which is what GM suggests if you're facing heat issues, it cools down. I know, because I've done it in 88F air once, and it did work.
The A8 really holds high rpm gears much longer than I would with an M7 and even more than feels comfortable, like down the straight at 5500rpm without a shift. You keep thinking "Really? Ok, computer, you know best..." and then you find out maybe it didn't in this case.
Just my .02, Chris
Just my .02, Chris
So even though an 'auto' by its design may run 'hotter' than a pure manual transmission, GM controlled the temps in the A8 well enough that it actually runs cooler on track than the M7.
Bish
Bish
Thanks, Chris
My point was merely that if you shifted the M7 the way the computer shifts the A8, it'd -probably- heat up similarly. But not exact, granted.
