Extra long front splash guards
I posted a thread last week with longer and wider guards from O'Reilly Auto. I think that a longer guard would provide added protection from paint nicks behind the doors, and if you just want to use these for track days they can easily be changed with only 3 screws per guard. For those of you that think your not getting any paint nicks back there take a flashlight in a dark garage and shine it at a angle at the paint I think you might be surprised. I bought CRE 24"X12" wide Black Textured splash guards from Real Truck $34.16
https://www.realtruck.com/cre-splash...FYSDaQodEAYABA
I used the existing bottom and side of the guard and cut the top and inside edge per the attached drawing. I listed all the dimensions to make it easy if anyone wants to get these. Also the 3 holes are not identical from side to side so I drilled 1/4" holes so you can adjust them as needed. These are 2" off the ground if your corvette is lowered you can cut them shorter or use the O'Reilly guards.
Cut these to 20" long, at 20-1/4" they hit when going over dips in the road.
If I understand correctly, do you have to remove the stock backing plastic in the wheel well to access the three screws? Then unscrew the screws and place the new splash guard and rescrew the screws? Did you need to get longer screws? Did you leave the stock backing plastic off when completed?
Thanks.
Thanks.
Also I noticed if I go over a big dip in the road the bottom of the flap hits sometimes so if your going to get these you might want to make them a 1/4 to 1/2" shorter. Good luck, I don't care what is on the road now cause nothing hits the paint.
Here's what I sent out, with some minor editing:
My new mud flaps started as 18" by 9" $13 ones from O'Reily or AUtozone. Positioning: The bottom edge of my mud flaps are 1-1/2" below the bottom edge of my side skirts and 3-1/2" above the ground; the outside edge lines up with the tire width, 2-1/4" out from the body at the bottom. I took kind of a lazy man's route when I first did this because I wanted to be able to make a change easily if I wanted. (Before I had used smaller splash guards that didn't provide enough coverage.) What I did was mount the new splash guards on the existing stock trim pieces. I did this because they are so easy to take off (one 7mm screw on the bottom then a bunch of snap-in clips all the way up), plus I could do the work on my work bench rather than under the car. Plus no uncertainty as to what I might be drilling into in the car. You may or may not care for the look; I think it is fine for what I want.
So I measured where I wanted the flaps to be in relation to the outside of the stock piece (2-1/4" away from the very bottom lined up with the tire width; fairly close to the stock piece at the top). On the workbench I used some clamps to clamp the new flaps to the stock trim piece, adjusted the fit and marked with painters tape the areas on the inside to be trimmed off. I trimmed to match the shape of the stock trim piece on the inside. Also trimmed a bit off the bottom once everything was done to make it horizontal.
I then reclamped the new piece in place on the stock trim piece, checked adjustment and drilled five 1/16th inch holes where screws would go. Just small starter holes as the plastic is relatively soft. There seems to be plenty of room behind the stock piece for small screws. I did the one near the bottom outside first, inserted a 1/2" x 8 (or 10; can't remember) black panhead screw to hold it, then did another and screwed it, then the rest. Screw easy; easy to strip the plastic I assume. I went back to the car snapped everything back in place and replaced the 7mm screw on the bottom. Note there is a tab on the inside of the stock piece that slips in a slot and the bottom tab goes between the side skirts and body; with no skirts just on the body. I mentioned my addition to several people looking at the car and no one had noticed. However, if you decide you don't like the look and want to get custom ones, just remove one screw and snap them off. Here's a side picture from my first attempt with smaller flaps and before side skirts showing the stock trim piece and the mud flap:
I then reclamped the new piece in place on the stock trim piece, checked adjustment and drilled five 1/16th inch holes where screws would go. Just small starter holes as the plastic is relatively soft. There seems to be plenty of room behind the stock piece for small screws. I did the one near the bottom outside first, inserted a 1/2" x 8 (or 10; can't remember) black flathead screw to hold it, then did another and screwed it, then the rest. Screw easy; easy to strip the plastic I assume. I went back to the car snapped everything back in place and replaced the 7mm screw on the bottom. Note there is a tab on the inside of the stock piece that slips in a slot and the bottom tab goes between the side skirts and body; with no skirts just on the body. I mentioned my addition to several people looking at the car and no one had noticed. However, if you decide you don't like the look and want to get custom ones, just remove one screw and snap them off. Here's a side picture from my first attempt with smaller flaps and before side skirts showing the stock trim piece and the mud flap:
I really like your method of solving the issue for extra wide and extra long splash guards !!!
I even have an "extra" set of the stock GM pieces from our Stingray I can use, without touching the set that will be coming on our Grand Sport (on order now). I bought the GM Accessory ones for our current Stingray and they gave me the stock pieces. I believe it's the same ones that are on the GS so I hope to use them, if not, I'll just use what comes on the GS.
Are you still pleased with how this worked out, after a few months of use? If you were doing it again, would you still go with the 2.25" out from the edge, and 1.5" below the bottom edge?
What did you use to trim the excess plastic off the bottom to make it horizontal, as well as the inside edge? Razor knife, or heavy duty scissors?
Sure appreciate if you could post a couple of clear pics from the front and back view. I am thinking of using alum pop rivets to attach the new piece to the stock GM piece instead of screws, then paint black. Might be a little less noticeable.
Thank you.....
Richard
Last edited by Strake; Oct 15, 2016 at 12:53 PM. Reason: removed question for pic with skirts on..... found it.
Thank you.....
Richard
So far everything is fine with the splash guards (3,200 miles). As noted in my earlier thread I originally started with the somewhat smaller mud flaps and later switched to the larger ones. After that switch I wouldn't change anything. They seem to work well, although even with the side skirts I do notice a couple of very fine chips, but nothing I can't fix with Dr. Color Chip over the winter. Nothing like some chips I have seen in pictures of some folks cars. I used black finished screws for two reasons. First, I was able to remove them easily when I switched to the larger ones; pop rivets would be a pain to drill out of soft plastic. Second, the first time I did it I used a couple of regular screws that I painted black. The paint chipped off fairly soon thereafter; I presume that would happen on painted pop rivets. As to cutting the flaps, I don't recall that I had to cut the bottoms, just aligned them horizontally, but on the inside I used tin snips, which are like large scissors designed to cut sheet metal. I think all the pictures I have of the mud flaps have been posted within this post but I'll look. As to the measurements from the bottom of the side skirts and distance from the ground, they were by default as I aligned the top of the 18" mud flap to be where the stock one ended, just below the main wheel arch guard, and that is where the bottom ended up. Lastly, note that at the bottom of this thread there are references to a few related posts.Good luck with yours.--Bob
