PowerStop Z26 vs Carbotech 1521 Brake Dust
#81
I'm going to order a 2017 Z06 here soon and I think this thread has convinced me to go with the powerstop pads instead of the carbotech pads. It looks like the Z23 is the less aggressive pad and the Z26 is more aggressive. My thought is to go for the Z26, is there a reason to consider the Z23? Has someone found a good reseller to purchase these from?
Thanks!
Thanks!
#83
I have a extra box of the 1718's Z26's for the rear of the Z06
I'll take 40.00 shipped in the US for them. Just PM me
thanks.
thanks.
#84
Just talked with the folks at AutoAnything.com and they're all out of the Z26-1718 (rears), but they have fronts (1405) in stock. Also, if you spend $99+ use the code "LITTLEDEAL" to get $20 off your order!
Can't wait to get the rears and then swap my pads!
#86
Did you try Jegs?
#87
Exactly.... You can use a new microfiber towel to wipe off all 4 wheels, barrels and all after a few hundred mile drive and the towel is barely dirty. As close to NO dust as you an get... No other pads produce less dust.
#91
Shipped and thank you for the extra 2.00 to cover the paypal!
I reused the factory hardware on my install. But there is new hardware in the box should you decide to use it! Should have them Monday!
post office tracking is 9505 5141 7786 6203 0147 10
#92
I got the Z26 have a hundred or so miles on them AMAZING almost zero dust and no squeal. Brake dust drives me crazy but was still not ready to chunk down $400+ on a set of pads. With these pads at 100 miles of hard driving I have a small fraction of the dust I would have with the factory pads in 10 miles of easy driving.
#93
I will be able to give you a direct comparison of rotor wear as I put more miles on my ZO6. I have Carbotech 1521s on one side of my car and Powerstop Z26 on the other side. This be a equal test with the rotors being exposed to the exact same braking and mph. When I get enough miles I will provide pictures of each side and measure the thickness of the rotors.
#94
these pads are the best thing you can do if you have black wheels.i had hawks on my 2012 and dusting was better,but nothing like these.over 200 miles on mine and the inside of my black wheels are still black.best $130 I ever spent on my Z.i sanded my rotors to scuff them up for the new pads like I always do and the scuff marks are still on the rotor.here are pics I just took.over 200 miles on the pads.i have not cleaned the insides of the wheels,still black.the scratches on the rotor were put there by me when I put on the new pads.i always scuff up the rotor to take any glaze off like honeing a cylinder.well the scuffing is still there.goes to show that the pads did not ware off my light sanding yet in 200 miles.amazing.when I put hawk pads on my other vette used the same sandpaper and within 50 miles rotors were smooth.
joeybsyc (07-27-2016)
The following 2 users liked this post by Joy c7:
george vee (07-28-2016),
joeybsyc (07-28-2016)
#96
Subscribe
#97
Dang, just installed $290 Carbotech 1521s on the front of my C6Z. I wish I had seen this thread before I made the purchase or before install. If they don't make the Powerstop Z26 for the C6 it would make me feel a tiny bit better.
Jesse
Jesse
#98
But don't feel to bad I have over $700 dollars invested in comparing the Powerstop Z26, Carbotech 1521 and the Hawk pads. At least everyone now has a true comparison of brake dust and rotor wear.
The following 4 users liked this post by gve:
#99
Join the club! I had bought the Carbotech 1521 pads for my C7 Z06 before I saw this thread too.
#100
That's too bad you could of saved some $ it pays to look at this forum often, theres a lot of good information.
