Mathematics test
the front slicks have the same overall diameter as the cup 2's of 25.7".
i believe my speedometer reads low on the track. is that true? what is my actual speed at speedometer indicated 50, 100 or 150mph?
how does my vette calculate indicated speed? wheel rotation? trans gear and engine rpm? some other way?
...or do the slicks only change my final gear ratio.
thanks for any help!
At an indicated speed of 100 mph you would be actually be running at 105. At an indicated speed of 150 you would be right around 158.
I don't know how much tire growth adds to speed but there could be differences in how each tire grows in diameter as it spins. The growth won't be much but it will be there.
The speedo uses electrical pulses from the Vehicle Speed Sensor in the diff to determine speed. The signal is first sent to the ECM and then to the speedo. I am not sure where the actual calculation takes place in the ECM or speedo module but basically it counts pulses to determine shaft rpm and then knowing the gear ratio and tire diameter can calculate speed. If tire growth is a factor they can account for that in the calculation.
Bill
