Dms flex fuel kit
Old Aug 17, 2016 | 11:17 AM
Billy Shashaty's Avatar
Billy Shashaty
Default Dms flex fuel kit
How have people gotten to the ecm under the passenger fender to install the white wire from the dms ff kit? Removing the fender or removing the lining?
Old Aug 17, 2016 | 09:54 PM
RowboatLS3's Avatar
RowboatLS3
You don't have to remove the fender completely. But remove the liner and the bolts to the fender closer to the door top and bottom and you can pull the fender out just enough to squeeze in there to do the wiring.
Old Aug 18, 2016 | 02:42 AM
Billy Shashaty
Originally Posted by rowboatls3
you don't have to remove the fender completely. But remove the liner and the bolts to the fender closer to the door top and bottom and you can pull the fender out just enough to squeeze in there to do the wiring.
ty!
Old Aug 18, 2016 | 06:00 PM
Billy Shashaty
Easiest way is to remove the air fin or extractor on the fender. Once thats done the ECM is right there.
To Dms flex fuel kit
