Can someone tell me if the vitiesse throttle control has an affect on launch control?
No, it doesn't! But if you are not convinced of that then keep in mind that it has multiply settings, one being "SP 0"
which places the car in the stock as in NO Vitesse present position, so just set it on "0" when using launch-control.
All you have to do is set it to 0 for OEM response. They are working on launch control too though FYI.
I sell these and have one on the way that will get in tomorrow to play around with. It is a plug and play unit right over the gas pedal and they offer a 30 day money back guarantee so if you don't like it, you can send it back.
The more I use it, the more I don't like it. I now have it set to SP0 most of the time. The throttle response can be very jerky and very abnormal from time to time...
I'd send it back, but am well outside of the 30-window now...
You can send it back to us for a full refund !
If you're having a "Jerky / abnormal throttle response" even at SP0 then you need to look at what is causing this. SP0 ( Stock mode ) is same as having No Controller installed.
On a Z06, I recommend SP3 or SP4 and leave it there for a while...
