ZL1 Addons Tow Hooks
So I bought a set of the chrom-moly 'premium' tow hooks from ZL1 Addons. Nice product and easy to screw in. Does anyone know how these hold up to the elements? Are they going to rust out?
Wondering if I can leave them on or need to install them for events only.
They'll probably stand up to the weather just fine. I have the ZL1 Add Ons front and rear ones for the track.
I remove mine between track events. Somebody would probably remove them for me in a parking lot if I left them in for daily driving.
Take a look at this thread in the C7 General section to see what people think of leaving them in:
https://www.corvetteforum.com/forums...w-hook-in.html
Didn't consider the souvenir issue. Guess they're coming out.
Do people keep tow hooks for the chance they are disabled on the road or only when required by a track? I won't be tracking my car. Should I have one long tow hook for the chance I need to get pulled onto a flatbed? I would want to keep it in the passenger compartment for I don't like the looks.
2019 Corvette of the Year Winner
St. Jude Donor '15
I leave mine in. My front unit I put in with blue loctite. So unless they have a large breaker bar with them it isn't coming out.
Does anyone one know what red color is the closest match for touch up on the red? I use they to pull my car into the trailer. First time I didn't protect it and got a few bite marks.
Now i I have a piece of leather I put between the loop and the hook.
St. Jude Donor '15
So if you ever need a flat bed you had better have your own that you know will fit and work.
RussC243 (09-10-2016)
Looking for a clarification-----many months back on another thread about these two hooks one guy (that seemed very knowledgeable based on prior posts) commented that these tow hooks are great for the track, but not the roadways. He said something about the tow trucks could use the hook to get us out of a ditch or an embankment, etc., but would not be able to use them to get the corvettes onto the flatbed truck.
Does anyone know anything about this? Thanks.
I recall that thread but haven't found it. IIRC the problem was the winch is centered on the flatbed while the tow hook is not
therefore difficult to keep the car properly centered on the truck.
I have the ZL1 tow hooks- front and rear. The Z06 has been pulled onto a flat bed tow truck 3 times using the front hook with no problems. I would think there would be considerably more effort in using the hooks to pull the vehicle out of a ditch than it would be to roll it up the incline bed.
time2run,
I 'think' it was a matter of being able to pull the car straight enough to get to go on, and stay on, the ramp, etc. Versus, when pulling me out of an embankment or something, they don't have to worry too much about being straight----- they just have to get me back up the street.
But you say they worked for you 3 times (I won't ask how why you needed a tow 3 times, but it sure sounds like you are enjoying the heck out of the car----good for you!).
The winch on my trailer is centered. I've probably winched my Z on that trailer 200 times. It doesn't pull to the side but you do have to watch how the cable is feeding on the spool as it will tend to just coil on the right side as you get the car closer to the winch.
funz06 (07-08-2017)
Received 8,928 Likes
Bill
funz06 (07-08-2017)
