C7 Z06 engine loping
Old Sep 26, 2016 | 08:34 PM
K1600GT's Avatar
K1600GT
Originally Posted by 383vett
For real?
i went and ran it out of gas and put 5 gallons of 93 no ethanol (4.89/gallon) and absolutely no change. I was really excited because a few have had success. Oh well, can't wait to see what they say Thursday.
Old Sep 26, 2016 | 11:52 PM
gve's Avatar
gve
That's too bad I was hoping that was the problem. Let us know what they say on Thursday..
Old Sep 30, 2016 | 07:23 AM
K1600GT's Avatar
K1600GT
Took the field reps out for a few runs a they totally agreed something was definitely wrong. Ended up hooking up a 3 dimensional vibration device (Picometer) and found the chugging was very cyclical, was even worse when decelerating without any brake. Conclusion is a ring gear in the rear end that has variable backlash runout. So the backlash on one tooth is more than on another so when it comes around it has a space where it is not engaged and then it kind of free wheels till it hits the next tooth causing a noticeable bump. Makes sense to me as it is always the same no matter what gear, and the frequency increases with speed. Also, when he disengaged the torque converter so it was not 100% locked up the shuddering was very less noticeable. Seems the fluid in the torque converter would absorb it. I noticed the acceleration was much less with the torque converter disengaged.
I asked if this was a common problem and he said they had seen it a lot in trucks but he never would commit to it being a corvette problem. They are going to replace the entire rear end which is on back order.
Old Sep 30, 2016 | 08:15 AM
Higgs Boson's Avatar
Higgs Boson
Mine was doing this, I found it to be an airflow issue. I really don't think a new rear end is going to do anything.
I seem to have fixed it by backing off the screw for the by pass valve about 1/8 - 1/4 of a turn and doing a "Cleaned Throttle" reset which the dealer could do for you or you can use an HPT Scanner to do it for free.
I always would happen with 3 or 4 psi of boost at part throttle, felt exactly like surging I could induce with some old turbo cars when the BOV wasn't opening enough to relieve pressure from the intake. So for now, I think it is fixed but I could stand to drive it more...
Old Sep 30, 2016 | 08:57 AM
K1600GT's Avatar
K1600GT
I have always thought it was something to do with the supercharger BOV. Does it just as you are going into boost and about 0-4 psi. Where is this screw you talk about?
Old Sep 30, 2016 | 02:15 PM
Higgs Boson
Right in front of the engine. It's important to do a proper throttle reset also though. I am not saying this is the fix, but there is a high correlation on my car so far.
Old Sep 30, 2016 | 03:15 PM
K1600GT's Avatar
K1600GT
i'm gonna need a picture. Which HP tuners do you guys use? There seems to be a few of them. Some are a little pricey too.
Old Sep 30, 2016 | 08:14 PM
Higgs Boson
There is one HPT but there are two cable options, one Standard, one Pro. The Pro allows analog inputs like widebands, EGT, and other various gauges, etc. to be logged along with the PIDs built into the computer. You can use the AEM 30-0333 with the standard cable but everything else needs the Pro.
Old Sep 30, 2016 | 09:05 PM
K1600GT's Avatar
K1600GT
Just do Pro and be done with it???
Old Sep 30, 2016 | 10:09 PM
Speedforhire's Avatar
Speedforhire
It could be related to the three octane tables for fueling. :-(
I set all three to match and the car feels more responsive.
Old Sep 30, 2016 | 10:38 PM
Higgs Boson
not the cause
Old Sep 30, 2016 | 10:45 PM
Speedforhire
not the cause
There's always one in the crowd.
Old Sep 30, 2016 | 10:46 PM
  #33
Higgs Boson
yes.....yes there is. would you like me to stand out even more?
Old Sep 30, 2016 | 10:48 PM
  #34
Speedforhire
Ding! Ding! You win brother..........Peace!
Old Sep 30, 2016 | 11:20 PM
  #35
Higgs Boson
Old Oct 21, 2016 | 03:24 PM
  #36
K1600GT's Avatar
K1600GT
New rear end installed and no change. Now they want to put in new axle shafts. Lets see, new torque converter, new rear end, and new axles. Ridiculous.
Old Oct 21, 2016 | 04:49 PM
  #37
Higgs Boson
I already told you what it is. Tell your dealer to go pound sand.
To C7 Z06 engine loping
Old Oct 21, 2016 | 04:51 PM
  #38
K1600GT's Avatar
K1600GT
Yeah, we tried it twice, no change. Dealer is only doing what the mother ship is telling them to do. Dealer knows it is BS.
Old Oct 21, 2016 | 05:45 PM
  #39
davepl's Avatar
davepl
So our bypass valve has a preload spring adjustment I take it? It really should open around 0. Sounds like it's bleeding pressure off at 3-4 psi which causes you to feel surge. Higgs is suggesting increasing (or decreasing) the preload which should stop the bypass valve from cycling under light boost.
Frankly, I'm surprised this isn't an error (CEL) condition for the bypass valve to open in the presence of boost, but the ECU may very well get no feedback from the valve at all, so isn't aware it's happening (other than watching the MAP I guess).
Old Oct 21, 2016 | 06:34 PM
  #40
Higgs Boson
maybe try the other way....I will experiment more with mine as well.
