HALLTECH intake just installed!!!
Old Oct 5, 2016 | 09:09 AM
blakvette's Avatar
blakvette
Default HALLTECH intake just installed!!!
I finally got to install my Halltech intake last night.. pretty easy installation overall. I did have to play a little with it to get the hood to close and still have to adjust it a bit more to get the passenger front side of the hood to align perfectly (it’s almost perfect now though, nothing too crazy or bad lol)
I personally didn’t think this intake could make much of a difference considering I had already replaced the stock filter with a K&N filter... but... I was very wrong. I’m not sure if 30-50hp were actually gained as advertised, but I can tell you the car pulls way harder now and I feel a better throttle response. No traction on 1st or 2nd gear either (before I would dead hook from a 2nd gear roll)
I’m extremely happy I decided to get one
Old Oct 5, 2016 | 01:19 PM
3 Z06ZR1's Avatar
3 Z06ZR1
Sweet Yes I had to play with mine a little to get it all the way down in position. Fits perfect once in there all the way.
Did you get the Nomex sock too? The Nomex is felt as well it keeps the intake charge cooler more towards ambient temps. . 'Which helps keeps the timing full.
I run a double Nomex and swear the car feels better with it on.
Last edited by Steve Garrett; Oct 5, 2016 at 03:49 PM. Reason: No need to re-quote the OP, especially if you're the next person posting.
Old Oct 22, 2016 | 06:34 PM
JDMUSCLE's Avatar
JDMUSCLE
Can you tell me what you had to do to get the hood to close? I can't close Even after adjusting it.
Old Oct 22, 2016 | 09:02 PM
nekoz's Avatar
nekoz
Is any tuning required on the car after installation?
Old Oct 22, 2016 | 11:02 PM
freeman1215's Avatar
freeman1215
Check with Jim Hall about the hood clearance issue. The intake should fit without any problems and/or hood alignment, period!
Old Oct 22, 2016 | 11:16 PM
Z06NJ's Avatar
Z06NJ
Do you mean that the wheels were spinning if you punched it in either 1st or 2nd gears?
What I don't get is how they advertise this car is under 3 seconds 0-60 when we can't launch it properly due to wheel spin? It may just be me and not knowing how to take off the right way, lol
Old Oct 22, 2016 | 11:51 PM
Higgs Boson's Avatar
Higgs Boson
how did you route the coolant line? needs to go under the box/tube or under the airflow tunnel thing. also check your headlight harness interfering with the hood hinge.
Old Oct 23, 2016 | 12:28 AM
ernhart333's Avatar
ernhart333
I had the same problem and no matter how I moved and/or twisted the lines/hoses the hood was being slightly held up near the air box.
Most likely your rubber boot (that seals the center air duct to the hood grill/opening) is laying slightly on the top inner edge of the Halltec air box.
After several times of laying the hood down slowly while shining a flash light to determine what was holding the hood up, I seen that I had to fold that boot/seal edge down off the air box. But you must fold the seal down quickly and lower the hood before that rubber seal pops back up over the air box. Once you drive the car a few times the heat from the motor allows that seal to stay down but I still always check and make sure its down each time I close the hood.
If you play around with it and don't understand what I'm explaining, let me know, and I will take a photo tomorrow of that area and seal/boot folded down off the air box.
Old Oct 23, 2016 | 01:17 AM
Mopar Jimmy's Avatar
Mopar Jimmy
From: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
No, not with the basic Hallech CAI that the OP is talking about you just order it with the no tune filter from Halltech.
Old Oct 23, 2016 | 02:28 AM
nekoz's Avatar
nekoz
Awesome! Thanks for the info!
Old Oct 23, 2016 | 02:46 AM
lordofwar's Avatar
lordofwar
proper install hood will close correctly
Old Oct 23, 2016 | 04:03 AM
3 Z06ZR1's Avatar
3 Z06ZR1
Sweet I pretty sure the advertised increase comes with EVERY install!
Old Oct 24, 2016 | 02:22 AM
upcharger's Avatar
upcharger
I also really like my haltech intake... Its bad to the bone... considering the ram air system from them next!
To HALLTECH intake just installed!!!
