"Normal" oil consumption???
Old Oct 5, 2016 | 03:03 PM
AJay's Avatar
AJay
Default "Normal" oil consumption???
My car has 3500 miles on it and I have used 1/2 quart of oil since the 500 mile oil change. Is it normal for our engines to use a little oil? Having had an LS1 for the last 14 years I'm used to adding a bit of oil from time to time between oil changes. For the record, oil is checked when hot and per the owner's manual procedure.
Old Oct 5, 2016 | 03:50 PM
lgodom's Avatar
lgodom
There are some posts in this forum about oil usage if you do a search, but if you're only using 1/2 qt every 3000 miles then you're on the low side. It may improve as you put more miles on it.
Old Oct 5, 2016 | 04:29 PM
thebishman's Avatar
thebishman
I wouldn't worry at all about 1/2 quart (litre) in 3,000 miles personally.
Old Oct 5, 2016 | 06:39 PM
L8 APEX's Avatar
L8 APEX
My car is undergoing an oil consumption test right now
2016 12,400 miles on car as of today, the last oil change at 10,000 I voiced my concerns so a case was opened, per GM 1 qt in 2,000 miles is ok. I used just under 2qt's in 2000 miles and now they want to continue the test for another 2000 we shall see what the outcome is.
Old Oct 5, 2016 | 07:28 PM
Edwardz's Avatar
Edwardz
A quart every 1000 miles seems like a lot. Do you have any evidence of leak? My 2016 Z06/Z07 had a funny smell like oil burning for awhile that has now stopped. I concluded oil was spilled during a oil change and burned off. Good luck and I hope your problem resolves.
Old Oct 5, 2016 | 08:34 PM
pkincy's Avatar
pkincy
I think the genesis of the GM response was the 2001 Z06. Many including mine would burn oil under normal usage of a qt or more/1000 miles. Oil was cheap so I didn't worry about it, but many went apoplectic and GM came out with the Qt/1000 mile level as being excessive.
Car is many Corvettes ago, but still may have been my favorite Corvette ever, although the 16 Z is gonna take that spot over before long.
Old Oct 6, 2016 | 12:50 AM
lordofwar's Avatar
lordofwar
3200 miles since 500 mile oil change,still full
Old Feb 6, 2022 | 06:38 PM
grecoz06's Avatar
grecoz06
HI There, how did this play out for you?
To "Normal" oil consumption???
