Recalls on the 2015 & 2016 Z06
Just FYI, went in for my second oil change and there were 3 minor recalls out on my '16. SA said most Z06s have at least one recall.
Unfortunately, one of them has wiped out the specific mode gauges. The cluster is stuck in the Sport Mode gauge with the large circular tach. Pocket gauges are frozen. SA has no idea when this will be corrected but another recall to recall the recall will be forthcoming.
Otherwise, 1 year and 4,000 miles later, the car has been flawless. 2LZ A8.
Looks like it happened to my 2016 Z06 took it in last week for an alignment and Air Bag re-flash and another re-flash for an occasional stumble feels like the motor going to die but then catches when almost coming to a stop and then accelerating. My gauges are stuck in the Sport Mode and I think the Trans is also as now there is no performance differences from Eco, Winter, Touring, Sport and Track all feel the same.
Oh no, sounds like the Tesla plague (things get worse after "update") is affecting GM recall updates as well. I got a notice to bring it in for airbag flash, something about possible non-deployment of the airbag. Not just Corvette, though. My Spark EV is affected as well.
I have the airbag recall may hold off a bit and see
Received 4,553 Likes
2016 C2 of Year
2015 C3 of Year Finalist
Bad Dad (10-19-2016)
Had the airbag re-flash done, messed up display, so I had to re-set it.
Just had to figure out how to get it back to what I had before which I had only done once when I first got the car.
I verified the airbag reflash with HPTuners and nothing was changed in the actual tune. However, it did reset the display.
The following 2 users liked this post by Speedforhire:
Bad Dad (10-19-2016),
C7/Z06 Man (10-19-2016)
Good info about no changes to the tune and I think if your display is factory than nothing changed, mine was altered.
Just FYI, http://www.azmythrecording.com/studios/studio-a went in for my second oil change and there were 3 minor recalls out on my '16. SA said most Z06s have at least one recall.
Unfortunately, one of them has wiped out the specific http://azmythmusictech.com/your-classroom.html. The cluster is stuck in the Sport Mode gauge with the large circular tach. Pocket gauges are frozen. SA has no idea when this will be corrected but another recall to recall the recall will be forthcoming.
I had mine in for the first oil change and they said that airbag recall needed to be done. I just noticed after driving that all modes had the same display as well. Was wondering what was going on but now it makes sense as this is being brought up.
reflashes always make me nervous. Something always gets changed or reset. I am going to wait a while......I am due for my second free oil change....but I think I may wait till my third oil change before getting the reflash/recall done.....
TTRotary (10-22-2016)
Was going to take mine in for airbag recall but wanted to see what was going to happen first. My is going to be put to into hibernation in a few days so I will just wait until spring and make sure GM has everything worked out..
