285-35-19/335-30-20 Federal Tires GREAT FEEDBACK.
#61
Received 2,054 Likes
What are the odds this customer can can tell the difference between tires on the street?
Not for nothing, but the vast majority of people aren't in a position to tell us crap about tires. Companies are spending millions to match the PSS, and falling short. I find it hard to believe this low-bid third world country no name tire just outdid Michelin's flagship tire.
I for one am not willing to find out in the middle of a turn at 1.2G's.
If you want to save some money, get the Continentals. They're probably just as good on the street as Michelin PSS (and certainly close enough for most drivers) and you won't die if you push it.
http://www.federaltire.com/en/products.php
#62
I can chime in with first hand knowledge.
They do not rub 99% of the time.
If you're at full lock, the front very slightly rubs on the inner plastic fender liner.
So just don't go full lock in a parking lot.
They do not hold a candle to Michelin in grip.
Definitely not track tires.. They are noticably softer and will wallow a bit on high speed turn in.
between the extra sidewall and the softness of non run flat.
But they also ride much better! and add a little ground clearance... Which is nice if you daily driver your car and live up North with crappy roads and ground clearance issues.
And obviously crappy roads and big city pot holes lead to more flats. $100 tire replacement easier to swallow than $550.
And also, wall Mart will not be able to mount a 335 tire... You'll need a high end wheel and tire shop or the dealer
I think they are a great option if you have 2 sets of wheels. Throw these on your show rims and save the cup2's on OEM wheels for track days.
#63
It cracks me up that the OP started this thread for those who wanted a cheap street tire with great traction, but then he gets villified by those who only care about how it performs at the track? Gee, we have a super stiff extra low profile tire versus a regular higher profile tire and the first one provides a more responsive turn in at higher speeds? Duh, who woulda thought that?
Runflats also transmit every bump and/or groove in the road no matter how small, they suck in the rain, and are lacking for straight line traction - let alone the well documented low tread life and road noise problem when well worn. You can't even compare the ride quality between any runcrap and a regular performance tire, no matter what the brand. It does boggle the mind how some posters act on here
#64
#65
#66
Stiffer sidewall = less grip in straight line acceleration
Shorter sidewall = less grip for straight line acceleration
Ride quality isn't even debatable between either of the Michelin tires, no comparison.
Based upon the tread pattern my guess is the Federal tires will be better than in the rain versus the base car tires.
Not here to argue with a "village idiot" though
#67
"Runflats also transmit every bump and/or groove in the road no matter how small, they suck in the rain, and are lacking for straight line traction - let alone the well documented low tread life and road noise problem when well worn"
Nothing about track use, but if that's what you meant, I'm not sure I've ever ever seen anyone complain about the tire life of either tire at the track.
Also, I've definitely seen way more street tires than cup tires at the track. This notion that "most if not all people are using PS Cup tires" on the track is completely unfounded.
Your quote:
"they suck in the rain, and are lacking for straight line traction"
1.8 and faster 60ft on the PSS (and way better on cup tires) is hardly "lacking" and I'd bet it's even better than the Federals. At the least, the PSS will be very similar and the Cup tires will be much better.
Also, PSS don't suck in the rain. I've driven them in the rain on the street and on the track (twice).
MPSS are a fairly impressive all around tire, TBH. They're fairly impressive on the track for a street tire too, to be honest. They're no Cup2 or race tire, but they're pretty good.
#68
Your talking about the OLD GOODYEAR runflats on the C6 Z06.. They were as you describe but the new MICHELIN tire is a million times better
That old stuff is out the window long ago. The runflats beat the non-runflat easy even with BOTH BEING MICHELIN SS.
Been there. Done that
Just sold almost new Michelin SS's to get the runflat back on the car which is a CORVEtTE SPEC tire the non runflats are NOT! . The runflat has is better And far away the stock MPSS beats ANY non runflat on our Z06's.
You should get a new Z06 you would know a lot more about the new stuff.
#70
#71
#72
Review I stumbled upon comparing Federals to Michelin Cup 2s on track...
#75
Interesting. I would try the Federal's, but they are almost 37 pounds. That's almost 6 pounds more per wheel. Though I wonder how much that would slow me down.
#76
https://youtu.be/R5gKpI5chME
best lap is close, but as i see on federal very unstable lap times, almost 6sec from best to worse - too lot difference! Michelin is in 0.7sec room each lap! Insane performance!
That basically means the Federal is a hunk of crap.
#77
I would not use these tires for the track,but for $527 shipped for all 4 they should make good burn up street tires.
#79
I didn't time the laps but from the comments:
desmophile (11-28-2017)
#80
I like to deal with facts personally and not opinionated comments...they show the lap times, which there was one that was 4.2 seconds slower (possibly driver error?) throw it out and the difference between slowest to fastest was 1.4 seconds. I'm not a Federal rep, but to say the tire is going to kill you on track is flippant.
I've never once found a way to save money on tires on the track (aside from getting different sized wheels). "You get what you pay for" has resonated truewith tires than any other component I can think of.
