Poor HVAC
Old Nov 12, 2016 | 10:49 PM
Batman 357's Avatar
Batman 357
Default Poor HVAC
I’m I the only one with lousy HVAC. On day one with the car it was 95 degrees. The AC was just barely cool. I thought I did not have something right and called a dealer. They told me the auto control was no good on the C7’s and I had to turn the temp to low and fan to high. I did and it was better but not good. I added the seat cooler and still not a comfortable car.
Tonight I needed the heater. Same story. Turn the temp to Hi and manual fan. The seat heater also takes about 30 minutes to get warm. My 66 Pontiac had a better system without a seat warmer. No it has not been back to the dealer yet but it will be. This is shameful.
Old Nov 12, 2016 | 11:00 PM
24/Eray's Avatar
24/Eray
my 08 C6 was the same way but it worked, just slow to react sometimes. This car has been better but the temp sensor at least on the driver's side definitely works similar to the C6. My 16 Sierra (same controls from what i can tell) works the same way now that i think about it?
My 16 Jeep GC limited is quicker to achieve desired temp for sure..
but in all vehicles the heater and the ventilated seats work quickly are both sides the same way in your car?
Old Nov 13, 2016 | 12:19 AM
MikalMuh's Avatar
MikalMuh
With My C6 the HVAC was perfect. I too have noticed that the Z's AC is not as good. Sometimes it seems it's not cooling at all. I too plan to visit dealer about it eventually.
Old Nov 13, 2016 | 05:31 AM
Larry M's Avatar
Larry M
Ughhh that sucks
Old Nov 13, 2016 | 07:22 AM
Batman 357's Avatar
Batman 357
My 2008 C6 has great HVAC. The AC gets cold quickly it puts out enough air on auto and the seat warmer works great.
Old Nov 13, 2016 | 07:57 AM
cvp33's Avatar
cvp33
Strange. I'm very happy with the heat and AC, but not so much with the seat heaters. Agree on the Jeep GC, we have an overland and that thing is unreal. The heated steering wheel gets so hot you need to turn it off after 3 mins. Heated rear seats are nice to.
A little off topic, I believe there's a TSB on the heated seats correct? I need to check into that.
Old Nov 13, 2016 | 08:17 AM
jcthorne's Avatar
jcthorne
In the summer, if you are not getting sufficient cooling, press the recirculation button. The auto system will not do this for you. If you select this, the intake air is from the cabin rather than from outside. On a 95 deg day, you really need this.
If you have the glass roof option, you either need a solid roof or an insulated shade installed to keep the sun out on really hot days.
Old Nov 13, 2016 | 09:03 AM
BOBSZ06's Avatar
BOBSZ06
And then there is this.............
https://www.corvetteforum.com/forums...ff-normal.html
Old Nov 13, 2016 | 09:49 PM
charliebrown266's Avatar
charliebrown266
I had problems the day i drove my Z06 home! froze my *** off! no heat at all,next day it was fine,same for the A/C in the summer, Had HVAC re flashed problem gone!
Old Nov 13, 2016 | 10:12 PM
sixt7L79's Avatar
sixt7L79
What does having the HVAC reflashed mean?
I bought my car June 16 and I noticed the air conditioner worked a little better than average but not great. I had it on auto the entire time. I did notice that the vents would flip back and forth from dash to feet outflow and then finally settle down to dash and feet air outflow
Old Nov 13, 2016 | 10:21 PM
dar02081961's Avatar
dar02081961
There is a setting for the fan control. It defaults to (if i recall) about 50% of the available fan speed in auto mode. It is adjustable to allow the auto fan speed to have up 100% speed. Once you do this its as good as the previous gens until it gets to over 90ish degrees out. Then you will need to run the seat fans and go bi level to remove heat from the floor area as well.
Old Nov 14, 2016 | 12:56 PM
charliebrown266
Default hvac
they are re programing the hvac controller!
To Poor HVAC
