Gas thread. Using E85 to bump octane.
You are from Texas, right? Practically every station in my state has it available.
Not arguing there, but if he does things carefully it should work. Do you not agree?
And it's no more difficult than figuring out how much Torco additive you need to add, or race gas to mix.
Torco and race gas do not have different fueling requirements from gasoline. Alcohol has completely different fueling requirements and combustion characteristics.
If he's really super careful he can get the mix right and get himself some E9 and then what did he accomplish? You can get E10 anywhere so then really, what's the point?
I haven't seen an E0 pump in probably 15 years.
And thanks for all the comments, I appreciate it.
[img]webkit-fake-url://2fe4d665-64b1-4709-9b2b-8c552b601d50/imagejpeg[/img]
Do you really think you will notice a difference between E10 and a scientifically measured 18 gallons of 91 E0 + 2 gallons of E85?
Are they available at the same gas station? How fast will it get old driving to two different pumps or even two different stations?
What happens when you drain your tank, put exactly two gallons of E85 and exactly 18 gallons of 91 E0, drive it around for half a tank or 3/4 of a tank and then need more gas. Are you going to recalculate every time? Or are you going to do this only when you want to race at the track and drain the tank every time and then measure?
All I am telling you with all this is that it's not worth your trouble. I am trying to make your life easier.
Buy gasoline. When you want a bump add some race gas from a 5 gallon jug of VP or use some Torco (race gas is my preference). It's quick, easy, and in your garage.
Alternatively, if you have E85 readily available, install a flex sensor and tune and your car will adjust spark and fueling automagically, just keep it under the maximum amount of ethanol your fuel system will support (maybe E55 on a stock Z06).
Keep it simple. The mixing thing gets old in a hurry, but I'm not the one dealing with it so it's all you, man!
https://www.corvetteforum.com/forums/c7-z06-discussion/3905777-took-my-2017-z06-to-the-dyno-got-vids-and-s.html
Your options to solve this issue are below:
Install the appropriate equipment to run ethanol fuels and tune the car for ethanol. This will give you outstanding power when using E85 however will void your warranty. It will also result in lower fuel range for the vehicle. (Warning opinion statement follows) Mixing fuels is a recipe for problems unless you are sampling fuel after every fill.
Add octane booster (torco is very popular). This will allow the engine to run with more spark advance however is expensive. This will not void your warranty but costs a bit more.
The DI system on these engines is calibrated for fuel with between 0 and 10% alcohol. Adding additional alcohol will create a fuel with more pre-ignition resistance however will also reduce the specific energy and not use all of the oxygen in the cylinder. The car will run lean.. period.
Would you add kerosene to improve fuel economy on your car? My answer would be no.
Not looking to get into an argument over this, but facts are facts. I have been playing with gasoline engines for a long time (including running alcohol go-karts).
Hope this helps, Chris
Im also going to call GM and bitch.
We cleaned house, lol.
Looking at the mix charts adding 16 oz of Torco to 10 gallons of gas raises the octane 5 pts and is a linear function. To raise 15 gallons of 91 octane to 93.5 would take 12 ounces of Torco. A 32 ounce bottle on Amazon is about 24 bucks and would give you two full tanks and a little more. Not really a bad deal to get your HP back.
Got a good chuckle when I saw Meth Lab. Thanks.
For what it is worth if I could not purchase 93 I would be buying Torco, and still may for track days.
http://www.ebay.com/itm/like/201069534095?lpid=82&chn=ps&ul_noapp=true
http://www.ebay.com/itm/like/2010695...&ul_noapp=true
If your looking for the octane booster you want the Torco accelerator.
http://www.ebay.com/itm/The-Best-Fue...YAAOxyFrNRzQN~
https://www.amazon.com/Torco-Acceler.../dp/B004ZO3VN0
They make quite a few things including lubricants.
Thanks, Chris
