Caster alignment tool
Does anyone remember who this was?
You can tell whomever answers that Rick with C7R said to call
you can check the website out - http://www.tpcracing.com/
https://gmtoolsandequipment.com/en-U...KU=CH-47960-10
The shop I'm going to use said they ordered the adapter about a month ago and have not received it yet so I want to buy it to get my alignment set to Mike Levitas's specs.
Thanks for any input.
Aaron
Aaron
It seems I need the bar from you guys, and the meter i buy online?
I had purchased wstaab's aluminum guide but I am trying to measure caster with the car on the floor and can't get my body in far enough to be able to hold the gauge against the adapter and read the gauge at the same time. That is when I bit the bullet and purchased the GM tool for $182. That lets me magnetically fasten my saw blade gauge to the adapter, pull my hand back, take a flashlight to light and read the gauge. .
As for the gauge you could purchase the GM gauge which is CH-47960 if you can find one on eBay for a reasonable price which would be in the mid $200s or you can use a saw blade angle gauge. There are several on the market that look they are made by the same company but are marketed under different names. I have the Wixey Digital Angle Gauge (WR300 Type 1). This gauge has a +/- 0.1 accuracy Vs the Type 2 having a +/- 0.2 accuracy. Since you are measuring caster that can vary between +0.8 to -0.8 and trying to set it either at GM's recommended 0.00 or DSC's +0.7 you want to have a gauge that is as accurate as possible. A +/-0.2 degree accuracy guarantees a 25% error right off the bat.
The advantage of the GM gauge is it takes some of the effort out of the measurement. When measuring with the saw blade gauge you have to remember which side of the car you are measuring as the gauge is reversed from side to side. The GM gauge has a setting for which side of the car you are on. With both gauges you need to have zero the gauge to the surface the car is on. That means a zero for each side of the car since the gauge reverses. I use a 6 ft long carpenter's level that I place on the floor next to the rear tire and running parallel with the tire. I place the Wixey on the level with the proper orientation for the side of the car I am working and hit zero. Then fasten the gauge to the adapter. If you are working on a 4 post rack with sufficiently wide runways for the tires it is much easier to make the measurement and to adjust caster/camber.
The front side of the rear LCA has more influence on Caster than it does on Camber while the rear side of the rear LCA has more influence on Camber than it does on Caster. It can be quite tricky watching two different gauges while turning wrenches front and rear to bring the rear alignment where you want it.
A problem with the DSC recommendation is the stock toe links don't have enough adjustment to reach toe settings of 0 or any toe in. You are basically stuck with toe out. The Granatelli toe links will provide increased adjustment range. It takes a lot of time to get it right even when you have done the adjustment several times.
Bill
Bill
Bill
Bill
Has anyone else had issues reaching DSC recommendations on toe?
Here is what the two look like together.
Bill
