Girodisc Rotors C7/ZO6/ZO7
#41
Former Vendor
St. Jude Donor '13
GIRODISC FRONT 2PC ROTORS FOR C7 Z06 WITH FACTORY STEEL ROTORS
http://www.xplosiveperformance.com/G...rs_p_4086.html
GIRODISC REAR 2PC ROTORS FOR C7 Z06 WITH FACTORY STEEL
ROTORS
http://www.xplosiveperformance.com/G...rs_p_4087.html
GIRODISC FRONT 2PC ROTORS FOR C7 Z07 WITH OEM CCM ROTORS
http://www.xplosiveperformance.com/G...rs_p_4084.html
GIRODISC REAR 2PC ROTORS FOR C7 Z07 WITH OEM CCM ROTORS
http://www.xplosiveperformance.com/G...rs_p_4085.html
ROTORS
#42
Former Vendor
St. Jude Donor '13
ROTORS
ROTORS
#43
Former Vendor
St. Jude Donor '13
The Girodisc system is a direct replacement for the OE disc
The central hat section of our rotor is made from strictly U.S. sourced 6061-T6 aircraft specification aluminum. The disc is made from our own proprietary cast iron, poured in the USA and machined from start to finish in house at Girodisc. The rotor utilizes a curved vane design, developed in racing to act as a centrifugal pump to force cooling air through the disc.
The rotor and hat have a floating mount system, which utilizes 8 or 10 high strength alloy steel drive pins, manufactured by Girodisc in the USA to our own specifications and cadmium plated for a long lasting corrosion resistance. These pins take the load from braking actions while maintaining the axial and radial float between the hat and disc. The pins are secured by grade 12 cap screws with hardened washers. In order to keep the rotors from making noise when cold, the pins are mounted with anti-noise spring washers on the rotor side which allow the rotor to grow with heat expansion but eliminate the rattle and noise associated with floating rotors. This float also allows the rotor to self center between the pads.
Once the Girodisc system is in place, simply replace the cast iron rotor when needed.
ROTORS
#44
Former Vendor
St. Jude Donor '13
ROTORS
ROTORS
#45
Former Vendor
St. Jude Donor '13
ROTORS
ROTORS
#46
Former Vendor
St. Jude Donor '13
ROTORS
ROTORS
#48
Former Vendor
St. Jude Donor '13
ROTORS
ROTORS
#49
Former Vendor
St. Jude Donor '13
ROTORS
ROTORS
#50
Does the caliper get discolored from the heat/tracking the car with iron rotors? My 2013 Camaro ZL1 Calipers turned from black to a bronze color. I have also seen non-Z06 corvettes that discolor their calipers from tracking due to the hear. Does it happen with C7 Z06?
#51
My red Z06 calipers haven’t changed color at all.
#53
Former Vendor
St. Jude Donor '13
#54
Former Vendor
St. Jude Donor '13
ROTORS
ROTORS
#55
Just asking..
I know it says direct replacement
I have a ZO7 with CCM and I am interested in replacing the CCM for your Rotors. Yours are the exact same size at the ZO7 CCM stock rotors?
Cant find the size listed anywhere.
#56
Former Vendor
St. Jude Donor '13
Bolts right up same size as the factory rotors, hundreds of them operating daily on both the track and the street. The necessary pad shape is FMSI 1405 which we can provide in several different compounds and manufactures depending on your application.
#57
Former Vendor
St. Jude Donor '13
ROTORS
#58
Former Vendor
St. Jude Donor '13
ROTORS
ROTORS
#59
Can you answer the question asked by LagunaSeca as I would like to know too. Thanks
#60
Former Vendor
St. Jude Donor '13
We recommend Race Technologies (Brembo) TS20 compound for front and rear for a dual purpose pads Complete pad set front and rear is $1090.00
