Tires
Old Jan 25, 2017 | 04:42 PM
Spowell637's Avatar
Spowell637
Default Tires
HS anyone switched from run flats to conventional tires on C7 Z06 and if so please sure your experience.
Thanks in advance
Old Jan 25, 2017 | 07:24 PM
Dfwz06's Avatar
Dfwz06
Ditched the crappy MPSS and went with nitto. Best move I coulda made. No more crazy slide to the side. Better ride. Corners just as well. Easier to give full throttle and control it
Old Jan 25, 2017 | 09:17 PM
MacManInfi's Avatar
MacManInfi
Did you drop wheel size? Or does Nitto have some tires that fit stock wheels? I didn't think they had anything except maybe the Invo which is more of a touring tire. About to need to buy a set of tires so I'm also shopping atm.
Old Jan 25, 2017 | 09:19 PM
Dfwz06's Avatar
Dfwz06
Invo come in stock sizes
Old Jan 25, 2017 | 09:22 PM
MacManInfi's Avatar
MacManInfi
I liked them on my Viper but haven't been able to directly compare the Invo versus MPSS.
Old Jan 26, 2017 | 03:00 AM
Danelain's Avatar
Danelain
Not stock z06 size that I could find, where did you find them?
Old Jan 26, 2017 | 03:07 AM
MacManInfi's Avatar
MacManInfi
Close. The rear tires would be .2" taller and .29" wider. Fronts are the same.
345/25ZR20, 285/30ZR19
Old Jan 26, 2017 | 06:42 AM
Dfwz06's Avatar
Dfwz06
The sizes are close and you wouldn't know there was a difference by looking at them
Old Jan 26, 2017 | 08:31 AM
blakvette's Avatar
blakvette
whats the lifetime on them?
To Tires
