Track Day prep
Old Jan 28, 2017 | 09:50 AM
cvp33's Avatar
cvp33
Default Track Day prep
Just finished at the dealer:
1) Rear diff flushed - Mobil1 Delvac with GM friction modifier
2) Transmission flushed - ATF4
3) Brake fluid flushed - Castrol SRF
4) Oil change - Synthetic 5w50 (not 10w50)
5) New brake pads - DTC 60/70
6) Installed GMPP brake ducts and backing plates
7) Previously installed GMPP auxiliary cooler
8) Favorite part, numbers inbound now
Up next a trip to DSC for the mag controller and alignment.
Old Jan 28, 2017 | 11:53 AM
Mordeth's Avatar
Mordeth
2018 C6 of Year Finalist
St. Jude Donor '10, '17
Very nice! Looks like you will be all set to start the next season. I'm working on mine now.
Old Jan 28, 2017 | 01:43 PM
Hit Apex's Avatar
Hit Apex
That should cover it! Are you running the Cups?
Old Jan 28, 2017 | 01:49 PM
Z06Shark's Avatar
Z06Shark
post a picture when done ...
Old Jan 28, 2017 | 02:02 PM
cvp33's Avatar
cvp33
Hitting the track for the first time in a Z06 so I'll be burning up the stock ZP's and learning how the Z handles. After these are done I'll go to the MPSS non-run flats. Once I get comfortable after 2 or 3 events I'll be looking for dedicated wheel/slick combo.
Old Jan 28, 2017 | 02:52 PM
Poor-sha's Avatar
Poor-sha
Track Rat
What's your first event going to be?
BTW, I drove a friend's Z51 that had the non runflat MPSS on them. I didn't really care for them but I can't quite put my finger on why. The car just seemed to move around a lot on them. I know the construction is different than the run flat MPSS that were designed for the C7.
Old Jan 28, 2017 | 03:00 PM
spearfish25's Avatar
spearfish25
I had standard super sports on my CTS-V. Very soft squishy side walls. It helped daily driving comfort but I emphatically would NOT want them on my Z06.
Old Jan 28, 2017 | 03:05 PM
thebishman's Avatar
thebishman
^ this.
I would have preferred that the car came without RFTs tbh, but it was designed around the characteristics of the RFT MPSS/MPSC2's, and imho when you change out the tyre to a non-RFT, you could potentially upset the handling 'gestalt' that GM designed into the car.
Bish
Old Jan 28, 2017 | 03:31 PM
cvp33's Avatar
cvp33
VIR in March is the first event. Clearly street tires will be limiting....probably not a bad thing for my first few events.
Old Jan 28, 2017 | 05:40 PM
Poor-sha's Avatar
Poor-sha
Track Rat
If it's the TrackDaze open track event I'll be there too.
Not sure if you're running the Cup2 or Super Sports but both are surprisingly capable - especially when fresh.
Old Jan 28, 2017 | 09:36 PM
cvp33's Avatar
cvp33
Yup, Track Daze. I'll be running MPSS ZP run flats, not SC2's. Just want to get familiar with the car. Coming out of the heavier CTS-V running 2:15's on slicks I want to inch my way towards the Z's capabilities.
Old Jan 29, 2017 | 08:55 AM
gonzala's Avatar
gonzala
My first tracking of my Z was if the charity event in Feb 16 at VIR. I'm heading there this year as well. I Need to look into what track daze entails. Of course, the charity event is not nearly the same as open course. I'd love to track the Z there regularly but the cost of too high for me at this point. Maybe some day soon. Enjoy the track at VIR it's sick fun!!
Old Jan 29, 2017 | 09:30 AM
cvp33's Avatar
cvp33
Yup VIR is my 'home track'. I've run close to 15 events there. The Z is way faster and way more capable, hence my cautious approach to discovering its limits.
Old Jan 30, 2017 | 02:27 AM
william wyatt's Avatar
william wyatt
Already been to the track today.
Old Feb 1, 2017 | 02:50 PM
Bill Dearborn's Avatar
Bill Dearborn
Have you taken the Spring Mountain Corvette Owner's school yet? It may not help an experienced driver's skills as much as it does a novice but it does let you play with a car like you own and provide some great information on how to set the car's systems for the track.
For instance you should run in Track Mode Sport 1 unless it is wet until you get used to the car and how PTM mode works. Wet mode works great on a wet track and can provide a very good lesson on how PTM works before you try it on a dry track.
Bill
Old Feb 1, 2017 | 09:53 PM
cvp33's Avatar
cvp33
Haven't done Spring Mountain but want to. Going to hunt down Poorsha at VIR for some instruction.
Old Feb 2, 2017 | 01:25 PM
Poor-sha's Avatar
Poor-sha
Track Rat
Looking forward to it!
To Track Day prep
