Z07 Pagid RSC1 impression?
crap really? RSC1??
No problem going WOT at or shortly after apex if you're in a PTM mode.
PTM is predictive so you can hammer the accelerator and PTM will apply the max amount of power the car can handle.
Yeah, it's a "nanny". If you turn everything off you're on your own, but I like ABS, PTM, etc. You can hear PTM operating if you get a little too aggressive at track out, but when I'm in Sport 1, 2, or Race I never hear it.
I've read that even pro drivers are faster using PTM than with it off.
"No problem going WOT at or shortly after apex if you're in a PTM mode."
I find this hard to believe. I saw a video on YouTube with a guy in a C7 Z06 in Sport 2. He was in fourth gear doing 80MPH, going straight on cold tires. He floored it and spun the rear tires. Back end came around on him. Went off the track hit a dirt berm and the car flipped over. Fortunately he was not hurt.
Received 8,928 Likes
PTM seems to activate in turns below certain speeds. I have also found that I can't go completely wide open exiting every turn when PTM is active. Accelerating out of Turn 1 at VIR PTM activates before I hit half throttle and if I try to go full throttle from that point the back end kicks out. However, if I modulate the throttle so PTM remains active and slowly increase it I can be at wide open throttle earlier and the car literally shoots out of the corner. However, when I am exiting Turn 12 (Oak Tree) I can go wide open as soon as I start to unwind the steering wheel and PTM will keep the rear of the car planted.
Bill
Bill
