Plastic Intercooler Tank
Old Mar 19, 2017 | 09:09 AM
Bad Dad's Avatar
Bad Dad
Default Plastic Intercooler Tank
Just a question. Has anyone removed the stock tank and used a aftermarket tank inline only? Daily Street driving and Drag Racing use, No road track.
Old Mar 19, 2017 | 01:31 PM
383vett's Avatar
383vett
I've thought about it but haven't acted.
Old Mar 19, 2017 | 01:38 PM
T/A KID's Avatar
T/A KID
Do both.... I run a plastic edelbrock tank and the factory tank.... makes fluid capacity changes very easy, no more worrying about "air bubbles" and the tank is like $60 from edelbrock
Old Mar 19, 2017 | 03:04 PM
Bad Dad's Avatar
Bad Dad
I have an aftermarket coolant tank inline to add Ice to for Drag strip this worked well in my Whppled then f1x procharged 5th gen Camaro, that being said I don't see a need for the small plastic tank sitting down low keeping a air bubble. But maybe doesn't matter for Street Strip car
Old Mar 19, 2017 | 04:09 PM
C7/Z06 Man's Avatar
C7/Z06 Man
Yes, I have done this with an approx. 1 gal. plastic edelbrock tank with it's mounting bracket, modified/cut stock hose. I seen no real improvement, so I took it off. See my thread below for pics, etc.
https://www.corvetteforum.com/forums...lant-tank.html
Old Mar 19, 2017 | 04:56 PM
Bad Dad's Avatar
Bad Dad
Originally Posted by C7/Z06 Man
Yes, I have done this with an approx. 1 gal. plastic edelbrock tank, bracket, modified hoses and seen no real improvement; so I took it off. See my thread below.
Awesome captured the PID pic, the stock tank is in return loop and it wouldn't matter if it was removed as long as I had the upper tank in the system For ice. Living in Fla we battle heat I'm going Ice water, octane, and flex fuel sensor I really don't want Meth for a street strip car. And you are correct the lower tank can stay in or out with no difference in my op. I will be removing it when I have a reason to pull off the front fascia... Thanks for the link.
To Plastic Intercooler Tank
