More Z06 intake testing and R&D....
Former Vendor
If you ever need any tuning help with yours no problem. I've had mine out at the last 4 1/2 mile races and I normally log the runs and make minor tweaks if I see anything out of place. The best way to get in to understanding your tuning is to learn how to datalog and evaluate that data. With this platform its all super easy and straightforward.
2017 C5 of the Year Finalist
St. Jude Donor '08
Looks like I'm going to put another tune on my car for Torco 99 Oxygenated fuel, running Meth as well..
Maybe use that one on the road course sometimes, and Half/standing mile stuff...
Former Vendor
What I did with my tuning that seems counter intuitive but helped actual performance was dropping midrange timing to reduce torque and improve traction.
Terry do you when your filter will be available for purchase?
I have canceled my halltech...
Leeds.io
St. Jude Donor '14-'15-'16
Sweet!!!
Can you please explain in a little more detail why the filter alone can possibly mess with it enough to require a tune? I was under the impression the issue with the CAI was the incorrect size and flow around the mass airflow unit. If you're leaving the stock intake why does more flow through the filter potentially push the limit? I would have figured the stock tune could handle more air with all other things being equal. Lastly, would one of those aftermarket was air flow sensors help in this situation or are those things nonsensical in this application?
Thanks!
Best,
Gene
Thanks!
Best,
Gene
#33
Former Vendor
The factory filter by design diverts slightly more airflow in the center of the MAF housing than the perimeter, but doing this introduces a restriction.
When adding an intake with a huge filter you get slightly more airflow along the perimeter and slightly less in the center, due to the nature of how the filters are configured to reduce restriction, and this minor variation is enough to effect the sensor reading 8-15%. On the low end of that scale you get a leaner AFR, bit more timing, and of course more boost from the restriction reduction, and can get away with the stock tuning which is a little too rich anyway. On the high end you wind up too lean and need to change the MAF scaling in the tune to compensate.
In removing the restrictions within the factory filter we've fallen in to the same boat. What I don't fully know yet is where along the scale we'll fall. We could make an electronic device that sits between the MAF senor and DME to allow some tuning for those who don't want to tune. But HP tuners is so widely used and inexpensive it would be hard to justify development costs.
phantasms (04-18-2017)
#34
Terry, I noted that 8-15% in your last post, closer to 8% maybe good, closer to 15% maybe not so good.
Then I went to your first post and after looking at all the percent's it looks like the AFE with its slightly smaller air tube diameter (by my own rough measurement) and using the "low flow" gray filter looks like a better match for performance by not getting to lean to cause retard/reduced performance where as the 15% side maybe a problem. AFE may have done their home work.
Note: your setup has a pulley, etc. and the AFE and your stock replacement filter made approx. the same power so on a stocker the AFE may be a better fit and less likely to set a code from what I'm seeing here.
#36
Former Vendor
Worst case if nothing else if you are planning to tune anyway no reason to spend $500 for an poor fitting intake that does the same thing as a $100 filter replacement.
#37
Location: North/Central NJ - a.k.a. Gotti in the CFNE section
Received 1,551 Likes
St. Jude Donor '05
In dyno tuning each to get proper MAF calibration the AFE w/ dry filter and this drop in wound up with the same basic MAF correction factor. Since the AFE works OK with the stock tuning "most of the time", I am hopeful our drop in will also, but it's not guaranteed at this point. And we all know several cars have problems with the AFE and Haltech intakes so that likely will be the same case with this drop in. We'll have to see.
#38
Former Vendor
I don't believe a typical drop will hurt anything as long as its a dry filter. But unless you happen to need a new filter I don't believe it's an upgrade either, or at least have not yet been able to prove it is.
#39
St. Jude Donor '05
There was a strange anomaly in the testing though... While brand X flowed better than stock on the flow bench, it did not produce more HP than stock on the dyno. On my to-do list is to figure out why before I share that data.
#40
Former Vendor
Link to that dyno testing and data? I've found normally when people post results like that they fail to include a log of boost & AFR with them. If you are not watching everything carefully you could easily have a 10-15hp variance between runs especially on the stock tuning which is very temperature dependent.
